Stuck Compression Fitting On Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2011, 10:26 AM   #1
stuck compression fitting on copper pipe
remove a compression fitting from copper pipe
John Malarkey is offline   Reply With Quote
Old 01-27-2011, 11:26 AM   #2
Lightfoot's Avatar
Rewards Points: 272
cut copper just past old fitting, install new fitting.
Lightfoot is offline   Reply With Quote
Old 05-10-2011, 08:23 PM   #3
There is a tool i bought to remove compression fittings
I HAD TO REMOVE THE COMPRESSION FITTING BECAUSE THERE WAS NOT ENOUGH PIPE LEFT IF I CUT IT. IT WAS A TOILET SHUT OFF VALVE THE TOOL COST $19.00 AT LOWES AND SAVED ME A LOT OF TIME. IF YOU HAVE THE SPACE CUTTING IT OFF IS GOOD.
BUELL is offline   Reply With Quote
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
nicked copper pipe analogmusicman Plumbing 3 07-28-2008 08:54 PM
copper strap around copper pipe? analogmusicman Plumbing 3 06-04-2008 10:55 AM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 06:13 AM
