#1 |
Stuck brackets on bathroom sink
The white plastic brackets that you screw on the bottom of the faucet to secure it to the sink were apparently puttied/caulked onto the
thing (ppl who did the plumbing in our house were not too bright). We've tried everything to get them off so I can replace the leaking faucet. Is there a tool for those or something to loosen the putty or caulk or whatever it is they used?? HELP!!
#2 |
Persona Non Grata
If space is tight, then I'd use a basin wrench. Otherwise, a pair of slip joint pliers work wonders in loosening those nuts.
| The Following User Says Thank You to VIPlumber For This Useful Post: | kteymer (06-06-2012) |
#3 |
A "Handy Husband"
I use my multifunction oscillating tool and cut them off.
| The Following User Says Thank You to rjniles For This Useful Post: | kteymer (06-06-2012) |
| Tags |
bathroom faucets, caulk, sink, stuck, tools ![]() |
| Display Modes | |
| Replace bathroom sink drain? | Dave321 | Plumbing | 2 | 06-07-2011 01:37 PM |
| bathroom sink stopper question - Pictures in thread | amodoko | Plumbing | 5 | 05-31-2011 06:24 PM |
| Remove bathroom sink from cabinet stuck with silicone | Bucker | Plumbing | 5 | 09-10-2010 03:15 PM |
| Installing bathroom sink - drains off slightly less than pipe diameter | lazzlazz | Plumbing | 17 | 05-21-2010 06:12 PM |
| bathroom sink pressure issue. | tgamblin | Plumbing | 4 | 04-27-2009 01:21 PM |
