Stuck 90 On 3/4 Black Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2010, 09:34 AM   #1
Stuck 90 on 3/4 black gas pipe
I have a gas pipe in the wall I need to move for my new oven. I have the drywall off and the 90 I need to remove is STUCK. I was thinking I could cut the fitting off, does that seem ok?
NASCAR9 is offline   Reply With Quote
Old 12-12-2010, 09:38 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,...If you Cut the fitting off, there'll be no more threads to attach a new fitting...
What's the ultimate goal,..??
Old 12-12-2010, 09:53 AM   #3
Bondo, I will not cut down to the threads, I will break the final layer.
The house was built in 1972 and the fitting has a brown colored sealer. I have had pipe wrenches on and it won't budge. My thought was to take my 4 1/2 in cutoff wheel and cut shallow then break the 90.
Old 12-12-2010, 09:56 AM   #4
Also, I will be cutting the fitting NOT the pipe.
Old 12-12-2010, 10:31 AM   #5
Plumb or Die!
Bigger pipe wrenches? Use snipes? You've got to be able to crack open a 3/4" fitting.
plumber666 is offline   Reply With Quote
Old 12-12-2010, 10:54 AM   #6
I've used larger pipe wrenches. I'm also not a small guy. I'm afraid I may break the pipe if I pull too hard.
I think my two options are:
1. cut the 90 and break the final layer.
2. Use a propane tourch and try a heat the fitting to break down the pipe sealer. I would rather not use this method.
Old 12-12-2010, 11:19 AM   #7
Plumb or Die!
I'd zip cut two grooves 1/4" or so apart, almost to the threads, then try to hammer a screwdriver between the cuts and pry the piece out. Then try the wrenches again.
Old 12-12-2010, 12:48 PM   #8
plumber666,
That is kinda what I was thinking. I let you know how it turns out.
Old 12-12-2010, 12:57 PM   #9
Owner
LateralConcepts's Avatar
... if it turned out you wouldn't be having this discussion
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 12-12-2010, 08:59 PM   #10
HVAC / Plumbing
Get some 36 or 48'' pipe wrenches & buck the pipe with 1 wrench . I've taken off fittings on houses built in the 20-30's
kenmac is offline   Reply With Quote
Old 12-12-2010, 09:29 PM   #11
To all,
I gave it one last try with my large pipe wrench and liquid wrench, it came loose. Thanks to All who gave their input!
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
running black gas pipe lukeg Plumbing 6 10-24-2009 11:16 PM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 12:39 AM
