Stubborn Tub Drip - Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2014, 05:58 PM   #1
Rewards Points: 83
Stubborn tub drip - help
I have an American Standard single faucet fixture in our tub - It's been dripping for a while. I finally pulled the cartridge today and replaced it and it didn't help one iota. What the heck? Can anyone offer any help or suggestions?
Thanks.
Missy
Missy Bloom is offline   Reply With Quote
Old 01-14-2014, 06:28 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
Did you get everything back in correctly? Are there any other adjustment or service points?
Old 01-14-2014, 06:37 PM   #3
Rewards Points: 83
Well, it was hardly complicated. Exactly three screws to detach and attach the cartridge. No other adjustment points that I can see aside from tightening these screws (and perhaps the screws on the piece behind it - but these are already very tight. Also - it is the cartridge and its workings that regulate the flow of water from drip to stream and it ought to be in that piece that the drip should be remedied - right? Am I missing something here???
thanks.
M.
Old 01-14-2014, 07:32 PM   #4
Rewards Points: 318
Originally Posted by Missy Bloom View Post
I have an American Standard single faucet fixture in our tub - It's been dripping for a while. I finally pulled the cartridge today and replaced it and it didn't help one iota. What the heck? Can anyone offer any help or suggestions?Thanks.Missy
Possibly o-ring got misaligned or slipped off during replacement. Try again and use a little lube on cartdrige.
Just a suggestion, if you don't mine waiting a couple days, go online or call american standard, and explain to them your issue. They have a lifetime waranty on most of their residential faucets. They may send you a complete rebuild kit for it, which includes pressure balancer, cartdrige, instructions, and lube for free. Scale and debris builds up over time. Best to rebuild it with all new parts.
Stay tuned, let's see what others recommend/suggest.
jmon is offline   Reply With Quote
Old 01-14-2014, 08:00 PM   #5
dannyoung85's Avatar
I have the same problem with my american standard tub/shower faucet. I replaced the gaskets and lubed everything up and it still has a slow drip. I will be calling american standard soon to see what info they can provide to fix the problem. I'm hoping there is not a defect in the mixing valve body.
dannyoung85 is offline   Reply With Quote
Old 01-14-2014, 11:41 PM   #6
Rewards Points: 83
Yeah - good point about calling American Standard. I think I'll do that too.
With this particular faucet, there are no points to lube, no o-ring to situate or jostle. It's just a fully contained cartridge that is screwed on at three points. The handle part moves, of course, but there are no adjustment points here, like I said. The points of contact are surrounded by rubber gaskets , but there is no "seating" the unit.
So yeah - I'm thinking it must be an American STandard problem that I hope they'll be willing to fix quickly.
m.
The Following User Says Thank You to Missy Bloom For This Useful Post:
jmon (01-15-2014)
Stubborn drip! sobro Plumbing 6 04-04-2013 09:14 PM
Periodic Shower Drip Wetchick Plumbing 3 10-10-2012 08:34 PM
Drip edge under felt Jeoroc24 Roofing/Siding 1 09-07-2011 10:40 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
Furnace Drip!??! acawley22 HVAC 1 01-10-2007 08:36 PM
