Stubborn Handle On Hot Water Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2010, 04:48 PM   #1
Stubborn Handle on Hot Water valve
I'm stumped on this. The Hot Water handle in my shower just refuses to come off. I removed the center screw and the darn thing just refuses to release from the valve. (I was able to finaly get the Cold Water one off, so I see hot it "fits" into the knotches of the valve.) There is clearly some mineral build-up that is causing this thing to grip onto the valve assembly.
What are my choices to get this thing removed? I was thinking some CLR to hopefully clear the mineral deposits - but I can't figure out how to get it into the rear of the handle.
The other thought I had was to just take a hack-saw to it and replace both handles (to match).
Are there special tools to remove these handles?
cody21 is offline   Reply With Quote
Old 05-23-2010, 06:40 AM   #2
There are inexpensive pullers for removing stubborn handles, available at home and hardware stores.
The Following User Says Thank You to Just Bill For This Useful Post:
cody21 (05-23-2010)
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 09:38 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
