Old 06-20-2012, 07:59 PM   #1
JOATMON
ddawg16's Avatar
Stub out Connections?
What is the better way to make the transition from the water pipes coming up in the wall out to the valves that will feed a facet?
In my existing house, I have a bunch of these....
http://cache.vendaria.com/integratio..._uid_202029381
They nailed them to a stud and the valve hangs off the pipe sticking out.
Besides the fact that they are PIA to solder, they are not actually the easiest thing to use.
What do the prfessionals use? I want to make sure it's secure and low maintenance....as in not having to worry about it.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 06-20-2012, 10:04 PM   #2
what type of pipe being used if soldering is a pain.
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 06-20-2012, 11:36 PM   #3
Persona Non Grata
VIPlumber's Avatar
Ddawg,
If running copper lines, then I use what you have. If it's pex before the stub out then I use a pex stub out elbow like this,
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
jaydevries (06-21-2012)
Old 06-21-2012, 01:18 PM   #4
JOATMON
ddawg16's Avatar
Originally Posted by VIPlumber View Post
Ddawg,
I was sort of wondering if those copper bars with the holes in them was a better option...I guess not....
Ok....thanks for the responses....I'll just use the cast elbows...
My
and
pex connections Arky217 Plumbing 3 02-29-2012 12:54 AM
Meter to main breaker cable selection and connections crankcase Electrical 10 07-25-2011 12:23 PM
concrete stub wall daltinator Building & Construction 2 03-29-2011 09:58 PM
Asko Dishwasher Dispenser came with Different Connections momfxit Electrical 0 09-16-2010 06:33 PM
bent the stub out redneckgeek Plumbing 3 01-07-2008 10:10 AM
