Is Structalite Up For Tub-setting (instead Of Mortar?) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2007, 08:55 AM   #1
Is Structalite up for Tub-setting (instead of mortar?)
We have a Crane San Marcos Armorplus tub, which is Crane's answer to an Americast steel/composite type tub product.
After installation (and they had already started tiling the walls) my husband and I noticed that when you stand in the tub that there is a loud creaking and moaning and noticable flex. Since they hadn't tiled the floor yet we ran a 3 foot metal ruler through the gap under the tub and were able to go all the way to the wall for the full length of the tub--was not set in a mortar bed; tub only supported at ends.
We had a huge argument with contractor who wanted to spray in foam to "fix" the problem. We insisted the tub be pulled out and reinstalled in a mortar bed. He finally agreed.
Now they are pulling out the tub and the tile guy is giving advice to the very young-looking plumbers that they should use "Structalite" instead of a sand mortar (which is what I've read should be used.) Help! What is structalite and is it up to the task of tub setting?? I need an answer fast, if possible, because we are surrounded by fast moving burly contractors now!
House_Amuck is offline   Reply With Quote
Old 03-19-2007, 07:02 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Use a mortor bed.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-20-2007, 06:09 PM   #3
We did talk them into using mortar. Hope they used enough. They had to push the tub down a tad to get it back into position, which is what I would expect.
Now that it has been 24 hours we should be able to check it and see if it is less squeaky/more stable. Next time we are doing cast iron. This was really a pain.
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Backerboard not in mortar -- How bad is that? House_Amuck Flooring 28 09-27-2010 10:33 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 08:38 AM
Can Structalite be used to set steel compos tub? House_Amuck Remodeling 1 03-28-2007 04:15 PM
can I reuse mortar bed ? mf915 Flooring 1 07-04-2006 07:14 PM
