Strapping Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2013, 12:06 PM   #1
Rewards Points: 50
Strapping copper
Am strapping vertical runs about every 18 inches. I am wondering about horizontal, doesn't there have to be some freedom on the horizontal runs?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-17-2013, 12:12 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Use plastic anchors at max spacing of 6ft for 1/2" and 3/4" pipe. I usually go 4ft. Plastic anchors will allow some movement
Old 01-17-2013, 12:15 PM   #3
Rewards Points: 50
Ok so should these be loose or snug? Also I already bought copper and was using a thin rubber seal if you will between the clamp an pipe, on the verticals.
Old 01-17-2013, 12:21 PM   #4
Plumber
Rewards Points: 452
The talons(first image) shown in this link work very well on pex or copper. They shield the pipe from direct contact with wood- no need for cushion strips
http://www.siouxchief.com/Support/Supply-Hangers
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (01-17-2013)
Old 01-17-2013, 01:29 PM   #5
Roofmaster
Rewards Points: 2,172
Ive used copper straps on copper pipe with copper nails for 45 years and never had a problem, so what are you all talking about ?????
Old 01-17-2013, 06:25 PM   #6
Plumber
Rewards Points: 452
Aren't you replumbing a whole house?
Get some pictures up sometime so we can pick you apart
Old 01-17-2013, 06:30 PM   #7
Rewards Points: 50
My original post deals with horizontal runs, I know copper needs to be able to move a little. Was wanting to know how to do that.
Old 01-17-2013, 06:34 PM   #8
Rewards Points: 50
Yep and nope! I'm no fool! Well maybe, this is the first bath and we are close to connecting back to the existing galvanized. Need to secure, cap toilet line, sink and connect main leads back to hot and cold, then look for leaks.
maybe if i fire it up, and there are no leaks i may brave the ridicule!
Old 01-17-2013, 07:29 PM   #9
DIY staff
Rewards Points: 7,174
Good luck with the fire up---
If you have some one else turn on the water--listen for air hissing---try to stop the water before the air leaker becomes a wet joint---less time wasted waiting for the water to drain out for the fix----
Old 01-17-2013, 09:04 PM   #10
Rewards Points: 50
Thanks for the tip!
Transition from 3/4" rigid copper to 3/4 soft copper TVC15 Plumbing 2 10-05-2012 06:30 AM
Soldering copper pipe in tight location- Help Needed Pics included amodoko Plumbing 20 08-11-2012 05:14 PM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 05:03 PM
Copper or PEX (and which PEX connectors) SFX Group Plumbing 3 11-03-2010 09:06 AM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
