Strapping - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2010, 12:58 AM   #1
strapping
can anyone tell me where drain piping is supposed to be supported with strapping, looking at my kitchen plumbing it apears that nothing is supporting the drains, is it not a code requirement to support the kitchen ptraps and piping for trap arm? thanks for any help, sorry if its a stupid question.
onelson is offline   Reply With Quote
Old 03-30-2010, 06:23 AM   #2
Nothing under a kitchen sink needs support. Connecting nuts are sufficient to hold everything in place. Only long horizontal runs need strapping.
If you don't know the answer, there are no stupid questions.
The Following User Says Thank You to Just Bill For This Useful Post:
onelson (03-30-2010)
Old 03-30-2010, 09:05 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That depends on how far it is travelling below the sink. every 4 feet for ABS and PVC is the rule. If for some reason it's coming out of the wall on opposite grade, it would be a good idea to support it somehow to get the water to drain properly. I had to do this in a friend's mobile home once, because the drain was coming straight thru the cabinet, and angling toward the floor. I had to strap it to a side wall to get it back on grade for him.
Journeyman Plumber
Simple question on strapping satz Building & Construction 8 11-27-2009 09:21 PM
Floor bounce joist sistering joehomeowner Building & Construction 24 05-10-2009 01:50 PM
Strapping a ceiling duburban Building & Construction 2 04-13-2008 01:34 AM
straping for basement ceiling handyflyer Remodeling 3 02-26-2007 09:46 PM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 12:12 AM
