Old 11-27-2012, 12:45 PM   #1
Strange Tub/Toilet interaction
My home is about 7 years old. The toilet in the master bath is just on the other side of the wall from the tub. Two months or so ago we replaced the toilet guts and the toilet seems to work fine now. However, we now have a new problem: Every time the toilet is flushed, a gurgling noise is heard in the tub. Worse, after a few flushes, sewer smells come from the tub drain. Running water down the tub drain instantly removes the smell, but after a few flushes, it comes back again. What is happening and how do I fix it?
vanda1 is offline   Reply With Quote
Old 11-27-2012, 03:26 PM   #2
Sounds like things weren't properly vented, OR there's no trap on the tub/shower drain. Is this bathroom on the first floor, and are the drain pipes visible in the basement ceiling below? If so, take some pictures so we can see how it's plumbed.
If there's no vent on the waste arm for the tub, then the big slug of water that passes by that branch when the toilet is flushed can suck the water right out of that trap.
Ishmael is offline   Reply With Quote
Old 11-29-2012, 05:10 PM   #3
Thank you for your reply. A venting problem makes alot of sense. This is on the first floor, no basements in this part of the country, so I can't take any photos. However, I know there is a trap. Since this worked properly for several years until recently, I am thinking a critter or something else may have partially blocked the vent. I need to get someone to get up on the roof to confirm. Thanks again.
Strange rotten egg smell while drilling into wood? miamicuse General Discussion 4 07-08-2012 11:35 AM
Strange Water Heater Issues tekimj Plumbing 9 04-25-2012 11:37 AM
Strange Smell - Powder Room agentphish Plumbing 1 11-16-2011 05:47 AM
Strange Master Bath 'Odor' MeatballCB Plumbing 12 09-17-2010 09:05 AM
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
