Old 01-17-2007, 08:42 AM   #1
They're all fixer-uppers
J187's Avatar
Strange strange problem, could it be the flux?
I know this sounds weird but could I have some bad flux maybe? I've sweated a fair share of copper pipes so far and I really haven't had a problem. Recently I moved my water heater which required me to sweat a few joints in both hot and cold sides. For the passed two nights I have battling a strange problem. Every joint on the cold sold, and the two extension pieces straight off the hot side are fine. However, on the hot side, right at the 90 degree elbow going down, I haven't been able to get ANYTHING to hold. Every time I make a new joint there it leaks! Its so frustrating. I'm not resoldering the same joint, rather making up new sections each time, each time it leaks. The joints that are leaking are the new ones I make and I make them on a bench vise, so its not a water/moisture issue. After racking my brain, I realized the ONLY variable between the pipes that held and the ones that wont, is that I opened a new can of flux after the cold side and two other joints that hold on the hot side. Thats when I ran out of flux and used a new can. Everything since the new can won't hold. Could the flux be bad or something? I'm going to try a new can tongiht, but I was just curious.
J187 is offline   Reply With Quote
Old 01-17-2007, 10:02 AM   #2
Wow, that is strange. Their are different types of flux's but I didn't think it mattered.
I'll assume you are cleaning your pipe ends and connectors, right?
When you remove your bad work, were you getting solder in the connection?
harleysilo is offline   Reply With Quote
Old 01-17-2007, 10:39 AM   #3
J187's Avatar
Well, for the most part, I'm not desoldering the bad work. I'm cutting and starting over. But I did desolder a couple of joints to have a look and it doesn't look terrible, but i'm not getting a completely even coverage. I'm definitley cleaning right, I've soldered over 100 joints(not a ton, but enough to get the hang of it) and never had a problem until this. I'm not thinking its the "wrong" flux, its the same stuff I"ve always used, I'm thinking something might be wrong WITH it.... Can't think of anything else. thanks.
Old 01-17-2007, 10:58 AM   #4
So are you soldering a section (the one that fails) on your bench, and then soldering it in place? Or are you using unions or something to attach it?
If you are soldering near the failing joint a second time you could be heating it up too much and causing the solder to not form a good bond.
I usually run all my pipe and fittings and then start from one end and work to the other doing all soldering at once as to not heat the joints up multiple times.
I am not a plumber.
Old 01-17-2007, 11:56 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I think harleysilo hit the nail on the head.,,,overheating.
Heat the fitting not the joint, and heat it just enough to draw in the solder, then quickly back off the heat.
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-17-2007, 12:13 PM   #6
I agree with Mike and Harley on the overheating. Since you are using the same brand flux, it SHOULD not be the problem. Along those same lines though, I have seen flux seperate in the can from being kept in too warm a place. Try stirring the flux up a bit or get a new can. I am preferential to Oatey flux. I have seen homeowners buy the cheap flux and wonder why they have bad joints. Wiping the solder joint with a gloved finger can also help alleviate problems plus making the joint look better.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-17-2007, 03:22 PM   #7
J187's Avatar
I am open to ANY suggestions, but I gotta tell you, I don't think it's overheating at all. I am making each section at the bench. I don't put the union on until I get to the house pipe. Then I solder both ends of the union at once. I know what part of the flame to use and I heat my flux to a gentle sizzle w/ a slight green hue and then I go in. I've done many, many flawless joints. There HAS to be something different here. I used bread in the pipe. I cleaned thoroughly, I wiped the joint after, I know enough to heat the fitting and not the joint, I heat the fitting where I want the solder to flow. I learned all that stuff the hard way before, lol. I made the cold side the exact same way and its fine.
Old 01-17-2007, 03:25 PM   #8
Journeyman Plumber
Ron The Plumber's Avatar
Is there enough room inside that pipe for heat to expand, lack of space will cause solder to spit out of the socket making it leak everytime.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 01-17-2007, 03:28 PM   #9
Did you try to use those pre-soldered parts? I used them together with new solders to get double insurance that there are solder falls in the joints....
KUIPORNG is offline   Reply With Quote
Old 01-17-2007, 04:52 PM   #10
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
One time I used a different brand of flux. I couldn't get it to work right. Back to the green Oaty cans and never a problem. Also, could solder be a variable?
Brik is offline   Reply With Quote
Old 01-17-2007, 08:08 PM   #11
What Ron said. You may have some moisture in the line trying to escape as you are closing up the last few joints. Try leaving a mechanical joint cracked to let off any pressure that may accumulate inside the pipe when heated.
gitnerdun is offline   Reply With Quote
Old 01-17-2007, 09:33 PM   #12
J187's Avatar
Ok, so I stopped and bought some new flux on my way home tonight. As soon as I got home I made up a new section and sweated it in. No problems whatsoever. Heater is working fine, no leaks...........I wasn't going to leave it at that. I broke out the first can of flux and sweated on a male adapter and an elbow to a spare couple of sections of pipe. I hooked up a hose and ran it. I swear to you, it leaks. Strange, huh?
Thanks everyone.
Old 01-17-2007, 09:41 PM   #13
Handyguy
Brik's Avatar
Same brand/type?
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
