Strange Sewage Smell Only During The Night Time - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2013, 12:36 PM   #1
Strange sewage smell only during the night time
In the master bedroom of my house there's a strange sewage smell coming from the ground (Atleast I think it is from the ground). This is only happening around 8-9pm PST and would last about 30-45 min. The smell doesn't happen everyday, there would be some days where there is no smell, then there are some days where it is very awful.
I would call a plumber, but kinda hard to source where the smell is coming from if it only occurs during that time.
Anyone have ideas what it could be? and whom I should contact?
edge323 is offline   Reply With Quote
Old 03-01-2013, 01:10 PM   #2
Rewards Points: 218
We had a simular problem in our laundry room. Drove us crazy, sometimes we would smell it really bad, other times seemed fine. We thought something was seriously wrong with our sewer system. Hired a pro, he found nothing wrong with our sewer system, turned out to be a dead rodent. He recommended not using poision bait anymore because, he said, you never know where the rodent will finally die.
That's why we don't use poision bait anymore. Just mouse traps so we can see them and remove them.
Don't know if it's related to your problem at all.
Is your master bath and master bedroom close together? Do all the drains seemed to be working good? Does vent stack pipe run up through your master bedroom walls out through the roof? Vent stack could be cracked, maybe someone forgot to glue pipe and it has disconnected somewhere allowing sewer gas to enter your bedroom?
They'll be other people joining the post shortly with some other ideas. Just guessing at this point.
jmon is offline   Reply With Quote
Old 03-01-2013, 04:37 PM   #3
Rewards Points: 13,296
How old is the house?
Reason I ask is often times I've seen some really strange ways vents were run in older houses.
When does everyone take there showers?
Septic or city sewer?
Heard any strange sounds coming from the sink, tub or toilet?
Old 03-01-2013, 06:32 PM   #4
Rewards Points: 218
You don't mentioned how long it's been going on? Is the smell stronger at the ground/basement level then maybe coming up through the floors to your mb?
Possibly check your drainage pipes in the basement leading out to your sewer main for leaks or cracks? Like the above post asks, do you have septic/city/leach field?
Old 03-01-2013, 07:39 PM   #5
Thank you for your responses.
Here's some answers to questions you guys asked:
Ans: yup close together , they're in the same room and it seems to becoming from the bathroom area (maybe right before it)
Ans: haven't seen issues with the drains
ans: No, I don't think so. Its a single family house, so i'm not sure if we even have vent stack pipes.. anyway to check?
Ans: I see... wouldn't it be smelly all day and not just during the night time?
Ans: House was built in 1960
Ans: yep. There is two bathrooms in the house and we use both of them daily
Ans: City sewer i believe
Ans: Nope, pretty quiet and sounds normal when we use it
Ans: Been going on since the last 2 years now
Ans: its a one story house. Seems to be smelling more at the ground level of the room.
Ans: Unfortunately, there's no basement in this house. It is a one story house w/o a basement. I could go underground through a trap door, but it is in a different room
Like the above post asks, do you have septic/city/leach field? Yep city sewage i believe. Do you think I should contact the city?
Old 03-01-2013, 07:48 PM   #6
Roofmaster
Rewards Points: 2,172
Is your house near any high rise apartments or condos?
Old 03-01-2013, 07:49 PM   #7
nope, not near any apts...its a corner house, but i have other houses surrounding.
Old 03-01-2013, 07:54 PM   #8
Rewards Points: 636
sewer gas can very in strength of smell due to weather and usage . it can be a lot of things some times it is as easy as a wax ring and you put your nose down at base and it smells strongest, to a trap being dry or siphoned out, to having a vent pipe coming apart in attic,to someone just venting into attic, to one time it was a recessed light against vent pipe and melted a small hole in pipe now that one took a while to find. it is a matter of process and elimination
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-01-2013, 08:55 PM   #9
Rewards Points: 218
wow! been going on for over 2 years. I wish I could tell you more, but I can't.
Like you suggested maybe call the city, have them come out and see if it's on their end before you call in a pro. Might save you some time and money. Worth a shot.
Maybe they can give you some additional guidance or recommend a pro in your area.
Also you can check angieslist.com or google.com for a reputable professional master plumber in your area.
Jay makes an excellent point.
Maybe invite some friends over and see if they can help you pinpoint the source better.
Old 03-01-2013, 09:04 PM   #10
Rewards Points: 1,770
I would suggest you call a local plumber that has a sewer camera.
Old 03-01-2013, 09:30 PM   #11
Roofmaster
Most of us are creatures of habit. What do you do between the hours of smell that is different than what you do all day?
Run Dishwasher?
Shower?
Sit on the throne?
As someone else said, The most common cause of sewer gas smell is a bad wax seal.
Have you ever experienced a sewage backup of any type, in any location?
Old 03-01-2013, 11:00 PM   #12
cool thanks guys, i'll check w/ the city and a plumber on angieslist.
Yeah there's nothing we do around that time that is plumbing wise... we only run the dishwasher every 4 days, shower in the mornings, and toilet wise.. well that's varies... the smell doesn't.
I'm thinking it might be the wax ring that you guys talked about. i'll call the city and find out!
Thanks again for the tips
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 11:08 AM
sewage smell cristal Plumbing 2 07-27-2011 07:12 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Carrier - ?s on Night time shut downs wilgo5234 HVAC 2 02-19-2008 08:54 AM
Bloody anoying night time bird chirping grrr fridgeman Pest Control 6 11-09-2007 12:30 AM
