Strange Pipe In Outdoor System - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2012, 12:48 PM   #1
Strange pipe in outdoor system
Greetings,
Our water system that comes in from the city and goes into the house has a side loop extension that goes into the garage. We think the previous owner put it in to feed into a water softener that used to be inside the garage. The softener is no longer there, and the inlet pipe, which comes from the city, is now joined to the outlet pipe, which goes to the house, by a flexible hose. The entire extension covers about 40 feet from the front of the house into the garage.
The strange thing is that there is a third pipe in between the inlet and outlet pipes. The third pipe is open at both ends, which rise up above the ground about three feet. If air is forced into one end, water comes out the other end, 40 feet away. The third pipe doesn't seem to be connected to the other two pipes in any way. So, I'm wondering if anyone has any ideas why the third pipe is there.
bponline is offline   Reply With Quote
Old 09-22-2012, 08:04 PM   #2
DIY staff
Rewards Points: 7,174
That sounds like an abandoned feed line---may be it was a leaker and replaced with a newer one---
Old 09-22-2012, 09:54 PM   #3
^^^^ I second that diagnosis.
VIPlumber is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Pipe will NOT budge HELP!!!!!!! mrsd Plumbing 2 03-21-2011 03:16 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
