Strange Faucet (hose Bibb) - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2007, 08:41 PM   #1
Strange faucet (hose bibb)
This is a hose bibb on the front of my house. Has anyone seen one like this? Anything unusual about it, or replacing it?
If I turn the knob, it turns and turns and then eventually water starts spraying out of both the faucet opening (on the left) and from all around the plastic ring that is right behind the knob.
Sound fixable, or should I have it replaced with a "normal" hose bibb that I could service myself?
Strange faucet (hose bibb)-faucet1.jpg   Strange faucet (hose bibb)-faucet2.jpg
pjpjpjpj is offline   Reply With Quote
Old 03-22-2007, 07:56 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Thats a commercial style faucet, replacement can't be done without opening the wall it's in, there are rebuild kits you can get for them, but not sure what brand that is.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-22-2007, 09:12 AM   #3
Thanks for the quick response, Ron.
"Opening the wall", as in, access from behind? Ugh. The previous owners finished a basement room behind it, with drywall walls and ceiling. I believe there is even a small closet right behind it, so it might require ripping out closet framing too.
Could access be gotten from the front, if the concrete around it (and maybe even part of a brick) were chiseled out? It is located in a hidden spot so I am not that concerned about looks when it is finished.
Would most plumbers be familiar with this faucet, and be able to "investigate" rebuilding it (meaning, figure out if it could be done, what brand it is, etc.) without tearing much out?
Old 03-22-2007, 05:47 PM   #4
Journeyman Plumber
Yes if can be identified, you can't remove it from the front, it can only be taken apart from the front.
It almost looks like an old woodford brand.
Old 03-22-2007, 10:06 PM   #5
Jurneyman/Master Plumber
It is a woodford, and it is not an old style. Still use them often as a matter of fact. The problem is in finding the parts. Most plumbing wholesalers carry or can get the parts. You would be hard pressed to find them at your local hardware store. If you do, make sure your main valve comin in to your house will shut your water off before even attempting it.
PlumbinginIA is offline   Reply With Quote
Old 03-24-2007, 10:08 AM   #6
Thanks. I am definitely not going to try it myself. I'm going to call around a few places from the phone book and see if they are familiar with Woodford hose bibbs, have done rebuilding of them, etc. Maybe they will have an email address so I can send them these pics first, before they come out to the house, charge me $100, and say "I've never seen one of those before, sorry".
Old 08-23-2009, 05:02 PM   #7
You Can Get Parts
Parts are easy to find for woodford here is a link to a picture guide yours looks like a model 20
http://www.griggindustries.com/page16.html
fcplumbing is offline   Reply With Quote
Old 08-24-2009, 07:12 AM   #8
Rewards Points: 1,512
Can you undo the packing nut behind the handle? Then replacing the packing may well get the faucet usable again.
Caution: sometimes faucets are so rusted together that when you put a wrench to them, you rip a hole in the wall and twist the entire assembly and pipes out and then flooding follows.
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Hose Bibb replacement MarkRollins Plumbing 2 07-02-2007 05:33 PM
replacing hose bibb leroyme Plumbing 23 04-16-2007 05:45 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 01:53 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
