Strange Clog - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 02:29 PM   #1
Rewards Points: 358
Strange Clog
I have a strange clog in my shower, I have never seen anything like it happen. But for all I know it could be very common.
My issue is that the drain is draining fine then all of a sudden it will stop draining, and start to fill up then all of a sudden it will drop down and flow fine, and it will just keep repeating this..
I removed the drain grate and augured the 8' of line until it connects to the main line, nothing came out.. My second shower, and all other drains appear to be working correctly as far as I can tell.
Any ideas?
cbzdel is offline   Reply With Quote
Old 04-02-2013, 03:18 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Did this just start happening or has it been an ongoing issue?
fetzer85 is offline   Reply With Quote
Old 04-02-2013, 03:25 PM   #3
Rewards Points: 34
Sounds like the vent for the shower is clogged.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
joecaption (04-02-2013)
Old 04-02-2013, 04:46 PM   #4
Rewards Points: 358
Just started happening over the past month.. I never though of checking the vent, I can pop that cover and try to auger that and then the drain in case it drops anything down into there..
Its a tub shower it it vents at the top of the tub where there is a metal plate about 3" in diameter, correct?
Old 04-02-2013, 05:18 PM   #5
Rewards Points: 13,712
Nope, the vent is a line that runs all the way to the roof.
Old 04-02-2013, 05:20 PM   #6
Rewards Points: 34
No, the cover is your tub overflow. The vent for the drain is going to be in the wall or your main stack depending upon your plumbing layout.
What kind of piping do you have? PVC/ABS/Copper/Cast Iron/Galvanized?
Dan
Old 04-02-2013, 05:46 PM   #7
Rewards Points: 358
All ABS drain lines.
Sounds like this could be more work that I thought
I have two or three vents coming out of the roof..
Or can I just shove a garden hose down them??
Seems odd that only this drain is acting up though, all other drains/toilets are working as normal.
Old 04-02-2013, 06:24 PM   #8
Rewards Points: 34
A hose might do the trick unless the vent is a branch. I'm thinking the blockage is closer to the tub side than the roof. Do you have access to the plumbing from below or a wall access panel?
Dan
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 11:48 AM
Strange Smell - Powder Room agentphish Plumbing 1 11-16-2011 04:47 AM
clog + gurgling Looper Plumbing 2 12-20-2009 08:15 PM
Slow leak under sink after fixing clog gunzour Plumbing 4 11-30-2009 09:27 PM
Sewer Line Continues to clog. Just Some Guy Plumbing 16 08-24-2009 10:38 PM
