Strait Nipple, Quick Response Appreciated. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 08:55 PM   #1
Rewards Points: 77
Strait nipple, quick response appreciated.
I installed a restaurant style sink and faucet. Included with the faucet there is a non tapered nipple that goes from the faucet to the female PEX connector with a nut in-between the nut tightens the faucet onto the SS sink back. I can't get it not to leak. Because of the nut that holds the sink on, the nipple is not tapered. How do I keep this from leaking?
bkvanbek is offline   Reply With Quote
Old 10-14-2011, 10:07 PM   #2
DIY staff
Rewards Points: 7,174
Did you dope and tape it? Could a standard nipple be substituted?
I have installed a few of those---I thought the nipples were standard taper on those--Mike---
Old 10-14-2011, 10:09 PM   #3
DIY staff
Straight nipples usually use a washer in the seat----Any washers in the set?
Old 10-14-2011, 10:45 PM   #4
Rewards Points: 77
I had used tape on one end, cause I partly put it together a while back. and I doped up the end with the PEX fitting. Tightened it until I thought something was going to break. Still leaked.
Can't use a tappered nipple, cause then the nut that goes on the back side of the sink won't go on.
But I think I got it, I took off the nipples and put on lots and lots of tape. So far so good.
Old 10-15-2011, 12:09 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like you got it fixed, but i'm not sure without guessing that I could picture exactly what YOU mean by "restaurant style"
Journeyman Plumber
Old 10-15-2011, 03:21 PM   #6
Rewards Points: 77
Big basin, free standing sinks and drainboard with a 6" high backsplash. The faucet mounts through the backsplash.
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
Quick Step perspective flooring dawnparkin545 Flooring 1 06-25-2011 12:51 PM
How tight can a brass nipple be installed? darsunt Plumbing 6 12-20-2008 10:09 PM
Need quick response..masking tape usaalways Painting 4 06-21-2007 10:57 AM
