-   -   Strainer Nut Stuck (http://www.diychatroom.com/f7/strainer-nut-stuck-78964/)
Zen Nomad 08-16-2010 08:45 PM
Strainer Nut Stuck
My first post and I searched as best I could for an answer. Here's the situation.
My utility sink has a loose strainer. It appears that plumbers putty dried up and crumbled over the years. While I was working with the connection of the pipes below during a leak, it became loose and now is not sealed - worse leak.
So, I attempted to remove the strainer nut to either put it back together so it will seal or replace the whole thing. Darned if I cannot get the nut to move - in either direction.
I have a strainer nut wrench with notches that fits underneath on the strainer nut itself. For the strainer I've tried using a drain wrench with the cross-hair sections, but they don't fit well and keep slipping.
I have also tried plier handles and even used vice grips on the pliers to give me more leverage. Not working.
I've tried to get liquid wrench in the threads, but I suspect that hard water has found its way into the threads and mineralized over time.
Is my only true hope to cut the strainer nut?
Any suggestions?
TheEplumber 08-16-2010 08:50 PM
199 Attachment(s)
I'd cut it. Theres a good chance the underside gasket is trashed too, Buy a new stainer and set it in silicone.
Use denatured alcohol to clean up the extra caulk
Zen Nomad 08-16-2010 09:35 PM
Ok, then... Any tips on the best way to cut it... small hacksaw, dremel with cutting tool?
epson 08-16-2010 10:02 PM
You can do one of the following:
1) You can drill holes into the nut from the basket strainer to the end of the nut and split it that way.
2) You can use a hacksaw and cut the nut.
3) You can use a nut splitter to do the job.
