Old 08-14-2011, 10:55 AM   #1
Stopped up Tub
Hi. Since my wife started using my tub, it's stopped up more than it has ever been. I poured a bottle of Draino gel and it didn't do anything. The Tub's drain has a metal component that the drain cap screws into, so it is difficult to get around them to hunt further down the drain for the problem. There is not access to the pipes since it is under a one piece shower/tub unit.
Should I try another bottle of Draino? A bottle of something else? What would a plumber be able to do that I'm not? Thanks for the assist.
Rick
RickVS is offline   Reply With Quote
Old 08-14-2011, 11:22 AM   #2
Persona Non Grata
VIPlumber's Avatar
Stopped up Tub
Hi Rick,
Exactly what kind of tub stopper do you have? Could you post or find a pic of yours? If we can get you access to your drain directly then maybe you could use something like this to clean out the drain:
Otherwise you'd have to go through the overflow and use one of these, which all plumbers should have. Here's what the set-up would look like:
Please do me a favour though. If you do end up calling in a pro please tell them about your use of chemicals in the drain. That way they can minimize the potential splash back and avoid injury.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
plumber666 (08-14-2011)
Old 08-14-2011, 01:17 PM   #3
Stopped up Tub
Thanks for the reply. I ended plunging the drain and it brought the hair up so that I could pull it out. Draino seemed totally ineffective. I wonder how it's been on the market so long.
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 12 05-03-2011 09:29 PM
Central A/C and Heat stopped working, but fan still blows blahblah HVAC 8 10-05-2010 07:41 PM
dishwasher stopped mid cycle joetab24 Appliances 1 10-02-2010 08:51 PM
Condenser fan stopped - no A/C - Please help! AboveTheBULL HVAC 9 06-28-2010 10:06 AM
Garage door keypad stopped working bklyn1028 General Discussion 7 02-17-2010 08:32 AM
