Stop And Waste Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2013, 09:45 AM   #1
Stop and Waste valve replacement
I recently purchased this house.
I have a shut off valve in my basement for an outside water spigot. The outside water wasn't working so I tried to open up the valve (not the waste) and water started coming out of the valve stem. When I tightened it, the water stopped. But I'm thinking the whole fitting needs replacing. Currently its a soldered fitting. I'm wondering if this is something that would be served ok with a compression fitting replacement? or should I replace with another soldered fitting? it's 1/2" copper pipe.
Andy
AJPLeBlanc is offline   Reply With Quote
Old 06-11-2013, 09:52 AM   #2
Handyman
If it were me in your situation I would just solder the fitting. My rule of thumb on my jobs is to replace what's there or at least bring it up to the local codes. But your compression fitting idea has me curious?
nicktools561 is offline   Reply With Quote
Old 06-11-2013, 10:15 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Open the valve and then snug the bonnet. It's not uncommon for shut offs to leak around the stem. Particularly on valves that don't get used much. If snugging the bonnet doesn't stop the leak, then replace the valve.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
MTN REMODEL LLC (06-12-2013)
Old 06-11-2013, 10:19 AM   #4
What's the bonnet?
Sorry if that's a stupid question.
Old 06-11-2013, 10:37 AM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by AJPLeBlanc View Post
What's the bonnet?
The bonnet is the hex shaped piece at the shaft which you tightened down... it has a packing under it.
If you do replace it... sweated copper.
Develop this skill if you don't already have it.
Before you go farther... get a meter key ($10 at Lowes).
Then locate the meter box (at the street?) and the valve out there.
Always know where the next valve up the line is before messing with any valve in the house. Know that YOU are able to shut off that source water just in case. On a practical basis this means to "exercise" these valves now and then (once a year is plenty)
Old 06-11-2013, 10:43 AM   #6
The main water shutoff is about 6 feet away (There is a T and a water meter between), and there is a water outlet about 3 feet on the opposite side (with another "outside" water sensor between).
I'll have a look at the bonnet, thanks for the information.
Old 06-11-2013, 04:30 PM   #7
Rewards Points: 446
You stopped the leak at the valve stem by tightening it which means you fixed it. Why replace it? The ability to tighten the "cap" that you tightened is there for just the reason you used it and not a sign that the valve needs replacing.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
TheEplumber (06-11-2013)
Old 06-11-2013, 05:24 PM   #8
Rewards Points: 13,446
It's called a packing nut.
If you do chose to replace it replace with a Shark bite ball valve, then there's no soldering needed.
Old 06-11-2013, 08:48 PM   #9
Roofmaster
Rewards Points: 2,172
What's the bonnet?
Its the packing nut. A bonnet is a hat worn by a little girl.
The Following User Says Thank You to jagans For This Useful Post:
DidIDoThat (06-13-2013)
Old 06-12-2013, 08:50 AM   #10
I forgot to mention that even when I loosen the valve stem, and there is water coming out of the base of the stem, no water comes out of the tap outside the house. This is the problem, basically I can't use my outside water source. Thanks for the tips guys, I'll try to snug the packing nut, and if that doesn't work, will replace.
Old 06-12-2013, 09:07 AM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 552
You can replace the packing that is under the packing nut you know. You seem eager to replace the valve....If you do replace it- don't use a compression style. Try to solder it if you can. Compression valves seem to leak after time
Old 06-12-2013, 09:08 AM   #12
MarginallyQualified
...there is water coming (past the packing) at the stem...
or just replace the 5 cent o-ring (aka packing)
Old 06-12-2013, 09:09 AM   #13
It's not so much that I'm eager to replace the valve, it just looks like it's a 50 year old piece, and I wasn't aware that they could be repaired.
Thanks for the input on the compression fitting, that's the information I was looking for. I'm pretty comfortable soldering.
Old 06-12-2013, 09:22 AM   #14
Rewards Points: 2,516
See if these photos help you. This shutoff would not completely shut the water off to the outdoor faucet. Came to find out the stem washer was cracked.
Stop and Waste valve replacement-stem-apart.jpg   Stop and Waste valve replacement-damaged-washer.jpg   Stop and Waste valve replacement-damg-washer.jpg   Stop and Waste valve replacement-full.jpg
hammerlane is offline   Reply With Quote
Gate Valves or Stop and Waste Valves Rich Plumbing 5 03-03-2014 02:29 PM
Stop Wast Valve racer808 Plumbing 3 10-09-2012 09:50 AM
repair Mueller 3/4 inch Brass Stop and Waste Valve dadcarter Plumbing 3 03-02-2012 08:27 AM
Shower waste pipe to toilet waste microbar Plumbing 2 05-17-2011 04:24 PM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 02:11 PM
