Stop Valves On Pex Tubing For Vanity And Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2013, 05:12 PM   #1
Rewards Points: 91
Stop valves on pex tubing for vanity and toilet
Hey everyone, have a hopefully simple question that I am having difficulty wrapping my head around.
The house I live in will be replumbed to pex water lines, the lack of shutoffs, poor layout, abandoned lines, and adding another bathroom have made me want to replace everything with a pex system.
I have everything figured out except for how to finish out the stop valves in the current bathroom. The vanity and toilet each have one. I have been told to run a drop ear support behind the wall and stub out a pex line from it. How then do you dress the pex line and support it to prevent kinks? im aware you would have a very small amount of pipe showing, but it would be seen at the toilet I would imagine.
Am I overthinking this or is merit to this? Would this be the kit I need?
http://www.pexsupply.com/Wirsbo-Upon...ted-10476000-p
The new bathroom we used outlet boxes, I will have access to the wall but I do not want to use them in this case.
Thank you all!
quackaddict is offline   Reply With Quote
Old 05-16-2013, 05:18 PM   #2
Rewards Points: 13,458
Nope, use something like this.
http://www.bing.com/images/search?q=...electedIndex=0
Once the drywalls finished and painted you add an escuntion, cut off the copper stup out and add a right angle 1/4 turn stop.
Old 05-16-2013, 07:59 PM   #3
Lord of Slums
Rewards Points: 1,974
I still go from pex to copper under the floor. I actually make all my copper drops, then just come through and connect the pex from under the floor. Oh, wait, you may not be able to soldier. Just do what Joe said
mj12 is offline   Reply With Quote
Old 05-16-2013, 09:00 PM   #4
Rewards Points: 91
Thanks for the answers guys, appreciating the input.
Old 05-16-2013, 09:18 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 566
I stub out pex quite often. Cut the pex about 1.5" from the wall or floor and you won't see hardly any pipe- but if your using Uponor then you should use copper stub outs because of the size of the expansion ring. They are available in different lengths- straight or 90
Old 05-16-2013, 09:29 PM   #6
Rewards Points: 91
If its just a little bit I can handle that..
I will be using crimp fittings. I just happened to see that kit.
Old 05-17-2013, 06:24 AM   #7
Rewards Points: 4,796
Use the eschutcheon plate, then paint the pipe the color of the wall.
jeffnc is offline   Reply With Quote
Toilet Won't Stop Running DIY Novice Plumbing 6 03-04-2013 08:38 PM
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
