Stop Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2009, 06:44 AM   #1
stop valves
Threaded, sweat, or compression type stops to join stop valves to 1/2" copper pipe for toilet and sinks. Is one superior to the other or is it just a matter of personal preference? I've looked at prices and found very little difference on a small scale.
newgarage is offline   Reply With Quote
Old 09-28-2009, 09:00 AM   #2
All work quite well but the one problem I have seen with compression type is that sometimes you cannot find the same brand if replacement is needed. This requires getting the ferrule off the pipe, which can be difficult. Threaded valves would make replacement easier and no torches in a small space. I use quality valves and sweat them on.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-29-2009, 11:09 AM   #3
Household Handyman
Rewards Points: 1,408
You state that you have 1/2" copper pipes already. Threaded fitting are out, unless you want to sweat an adapter to the copper pipe. Why not use the sweat stop valves? IF you are not that familiar with using a torch and necessary equipment for this, then the compression fitting may be for you. Dragon is correct though in that if you ever have to change the valve and cannot find that exact valve again, you may have to remove the ferrule, and that ain't easy. Good Luck, David
Old 09-29-2009, 11:59 AM   #4
Remodeler
adpanko's Avatar
Rewards Points: 150
Compression are the easiest, especially for diy'ers. Sweating on a valve is probably the most durable, assuming you sweat the joint correctly. Threaded is kind of a waste of effort because you are still making a sweat joint (like in sweat joint shut off valves), but then you have the additional step of screwing on the valve. And with a threaded valve, you have to worry about getting the male adapted soldered on such that when you screw on the shut off valve, the outlet is pointed in the direction you want it, or close too it, without having to over tighten the joint.
adpanko is offline   Reply With Quote
Old 09-29-2009, 09:23 PM   #5
you'll find that most plumbers will use compression these days. More than likely made by brass craft. Another side note on that is if you need to get the ferrel off just take a pair of channel locks and rock the ring back and forth and most of the time it will come off. Sorry another quick thing i just thought of is when it is time to replace the valve you either A have to sweat the valve off or cut the pipe making it shorter. hope it helps.
fhrace is offline   Reply With Quote
Old 10-01-2009, 09:46 AM   #6
Thanks everyone
Gate Valves or Stop and Waste Valves Rich Plumbing 5 03-03-2014 02:29 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 05:27 PM
Hinge Pin Door Stop exterior dws General DIY Discussions 5 02-17-2009 09:58 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
