Stop Leak Product Or Homebrew For Leaky Drains? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2010, 03:39 PM   #1
Stop leak product or homebrew for leaky drains?
Hi, all... new here
I encountered a situation involving a leaking kitchen drain that is very difficult to access. I searched google for some product that might seal such a leak from inside the pipes (pour down the drain) and found this at the PlumbingZone:
"Another real cool way to stop a leak in any type of drain pipe is with powdered laundry detergent. We do this when we have a small leak in a kitchen drain, trap, or a brass pop-up. Mix powdered laundry detergent with water until it is as thick as a thin milk shake. Pour the mix down a drain and don't run any water for about 12 hours. Walllllah! The leak is repaired."
Does anyone know of a product or technique that might work? The drain pipes are PVC
Jack
jack6128 is offline   Reply With Quote
Old 09-10-2010, 04:31 PM   #2
Rewards Points: 150
You can try that if you want to but I think you may make your situation worse if the detergent sets up hard and clogs your drain, your call.
braindead is offline   Reply With Quote
Old 09-10-2010, 08:52 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
I would like to see inside the Ptrap after that stuff solidifies
Old 09-11-2010, 08:27 AM   #4
you'd be better with something a little harder... like hydraulic cement. Until you go to use the drain, and it might be a bit like Seriously though, there is no approved product to fix a leak from inside the pipe. Regardless of how hard it is to get to, it's gonna have to come out. Or you can let it leak for a few years, then it'll be really easy to get to once the water destroys everything around it
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
H. A. S. (09-12-2010)
Old 09-12-2010, 09:59 AM   #5
Owner
LateralConcepts's Avatar
I agree with the_man... that's the dumbest thing I've ever heard.
Sounds like job security for someone. jack6128 - Did that post you found also have a line at the bottom saying something like: "We clean drains, Call us 24/7!" ???
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Proper product for a leak where the roof meets stucco? bgrimes Roofing/Siding 1 03-15-2010 10:13 AM
How does this pipe work, and how do I stop the leak? jamolei Plumbing 10 12-20-2009 06:45 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
How to stop a leak in basement wall? Ammons Home Building & Construction 6 03-04-2009 01:24 PM
