Stinky Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2012, 11:03 AM   #1
We have iron rich water In our home. To combat it, we have a salt softener system and also a greensand system. Recently we flushed the hot water heater, changed our adnode rod etc to rid the water of the sulfur smell. It worked for a while but the smell is back. Do you think I should put some hydrogen peroxide in the in-line filter to flush the hot water heater? Is bleach a better option? Any other suggestions? We have had this smell for years and I can't seem to control it b
tukka is offline   Reply With Quote
Old 12-11-2012, 03:18 PM   #2
If the odor is in the hot water only the water heater/anode rod are the likely source. However if the odor is in the cold water as well you likely have hydrogen sulfide in your water supply.
If the water heater is the source then the information here may be helpful:
http://www.waterheaterrescue.com/pag...r-heaters.html
Bob999 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
