Still Getting Sewer Smells After A Backup - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 09:04 AM   #1
Still getting sewer smells after a backup
Have a 3 story colonial built in '84. The septic tank out take pipe is located ceiling level of the basement boiler room. I had a blockage in the septic pipe with a bad back up a month ago, sewer water all over boiler rm, garage, & basement, after clean up including having tank pumped, I'm still getting sewer gas smells in boiler room.
Prior to back up a plumber advised we attach water softener discharge hose to a vented trap going into septic outtake pipe but I did not have an issue with smells until after the back up.
I've disinfected area and pipes, refilled trap, cleaned out sump pump (also in boiler rm) Had plumber check for cracks, none. Odor seems to be around large rubber gasket surrounding out take pipe.
Also would it be a good idea to re-route water softener discharge to sump pump drain pipe?
cu_pon16 is offline   Reply With Quote
Old 01-27-2013, 09:08 AM   #2
Rewards Points: 13,446
I'd never suggest dumping that water softner into a septic system. Why would you want to add 20 gals of water to the leach field?
Old 01-27-2013, 09:33 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
Smoke test the system if its sewer gas you'll know were its coming from no guessing.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
sewer smell
sewer backup and repair corsica Plumbing 2 11-06-2011 11:19 PM
sewer backup corsica Building & Construction 9 10-26-2011 08:24 PM
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 11:10 AM
funky sewer smells MeanGene Plumbing 9 08-17-2010 10:04 AM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
