Sticky Moen Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2008, 11:37 AM   #1
Sticky Moen Shower
I have a sticky shower faucet. It was sticking and it seems to be pulling out if the wall. So I removed the knob and sprayed WD40 and it has made it worse, it almost feels as if the shaft is bent. Any easy way to remedy this?
Thanks in advance for the help.
Gian V is offline   Reply With Quote
Old 09-23-2008, 11:09 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
A new cartridge. Pull it out and take it with you. Many hardware and big box stores stock replacements.
Kyle
Old 09-23-2008, 11:19 PM   #3
Registered User
Termite's Avatar
Be sure to turn off the water supply to the fixture first.
Old 09-24-2008, 12:46 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Details...Details....
Kyle
Old 09-24-2008, 06:22 AM   #5
Thanks for the help. Removing the cartridge...any secrets or tools that I may need. I pulled the pin and and can't get that back in. The cartridge should pull right out correct?
Old 09-26-2008, 06:42 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Yeah the cartridge pulls straight out. No unscrewing or anything. I pulled one out the other day myself....and it wasn't easy. Took the knob and retainer off and had to just keep pushing the stem in and out with some pliers...and finally came out.
Kyle
Old 09-26-2008, 07:04 PM   #7
the Musigician
DangerMouse's Avatar
i knew Kyle wouldn't tell you about the secret tool..... =o)
DM
Old 09-26-2008, 07:40 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
DM
Shhhh....ancient Chinese secret...
Kyle
Old 10-02-2008, 09:18 PM   #9
Have you called Moen yet? I have used Moen products for years and once in a while they get hard to pull or may even leak. Everytime, I have called Moen and they have sent a new cartridge for free. Fast delivery (2-3 days). Good products, Awesome service. Call 1-800-buy-moen. Ask for consumer support. (not customer service). Good Luck.
or try 1-800-321-8809
_____________________
KCarr
kcarr is offline   Reply With Quote
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
