-   -   Sticky Moen Shower (http://www.diychatroom.com/f7/sticky-moen-shower-27245/)
Gian V 09-23-2008 10:37 AM
Sticky Moen Shower
I have a sticky shower faucet. It was sticking and it seems to be pulling out if the wall. So I removed the knob and sprayed WD40 and it has made it worse, it almost feels as if the shaft is bent. Any easy way to remedy this?
Thanks in advance for the help.
SD515 09-23-2008 10:09 PM
A new cartridge. Pull it out and take it with you. Many hardware and big box stores stock replacements.
Termite 09-23-2008 10:19 PM
Be sure to turn off the water supply to the fixture first. :yes:
SD515 09-23-2008 11:46 PM
Details...Details....:wink:
Gian V 09-24-2008 05:22 AM
Thanks for the help. Removing the cartridge...any secrets or tools that I may need. I pulled the pin and and can't get that back in. The cartridge should pull right out correct?
SD515 09-26-2008 05:42 PM
Yeah the cartridge pulls straight out. No unscrewing or anything. I pulled one out the other day myself....and it wasn't easy. Took the knob and retainer off and had to just keep pushing the stem in and out with some pliers...and finally came out.
DangerMouse 09-26-2008 06:04 PM
i knew Kyle wouldn't tell you about the secret tool..... =o)
DM
SD515 09-26-2008 06:40 PM
DM
Shhhh....ancient Chinese secret...:chinese:
kcarr 10-02-2008 08:18 PM
Have you called Moen yet? I have used Moen products for years and once in a while they get hard to pull or may even leak. Everytime, I have called Moen and they have sent a new cartridge for free. Fast delivery (2-3 days). Good products, Awesome service. Call 1-800-buy-moen. Ask for consumer support. (not customer service). Good Luck.
or try 1-800-321-8809
_____________________
KCarr
