Sticking Water Turnoff Valve On Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2010, 10:03 AM   #1
Sticking water turnoff valve on toilet
I need to drain the water out of the toilet in order to install a new flusher unit. The water shutoff valve is stuck; probably corroded. It will not budge. I've tried oil and a hammer. Any suggestions?
jerryrice is offline   Reply With Quote
Old 10-29-2010, 10:16 AM   #2
I figured guys like you and Joe Montana would just pay someone to do these things?
You can try loosening the packing nut behind the handle - I'm guessing it was over-tightened at some point. But that valve's been under some serious stress already (a hammer?!?!). You're probably better off replacing the shut off valve.
Ishmael is offline   Reply With Quote
Old 10-31-2010, 10:56 AM   #3
Toilet Valve
Ishmael:
Thanks for the lighthearted reply. Yes; hammer. I will probably call a plumber because I don't want a shower to erupt in the bathroom. I'm also good at dancing.
Old 10-31-2010, 12:31 PM   #4
stuck valve
Why call a plumber just yet. Turn the mains off. Replace with a new valve if it requires screw on and you are set. It,s another matter if it needs solder. Kp
Kishthunderbird is offline   Reply With Quote
Old 11-01-2010, 02:52 PM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I had the same problem in my 1/2 bath. I ended up just shutting off the main and replacing the valve - it only took about 20 minutes (Yes I took my time because i rarely plumb).
CoconutPete is offline   Reply With Quote
Replacing Dishwasher - Water Valve Help? BCreed025 Plumbing 1 07-26-2010 04:01 PM
Leaking T&P Valve on water heater secutanudu Plumbing 22 07-06-2010 05:02 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
