Stee Woll Against Copper Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2008, 08:35 PM   #1
Stee Woll against Copper Pipes
How much of a concern should it be for me to plug up holes around copper plumbing pipes using steel wool. Will there be a reaction causing leakage in years to come?
jvpeters132 is offline   Reply With Quote
Old 02-09-2008, 08:49 PM   #2
Home Remodeler
Rewards Points: 164
I think you can buy plastic bushings for this purpose.
mikey48 is offline   Reply With Quote
Old 02-09-2008, 08:57 PM   #3
Clarification
I should have mentioned this in my original post. The steel woll against the copper piping is to stop the f king mice from going all over the place. They will chew through everything else I;ve tried including that spray "Great Stuff"
Old 02-09-2008, 09:27 PM   #4
Send a message via AIM to Marlin
I wouldn't do it. You may get a reaction between the two metals eventually corroding the pipe. One option is to insulate the pipe then do it. What are the pipes running through that you need to plug? Cement, drywall, wood, etc?
Marlin is offline   Reply With Quote
Old 02-09-2008, 10:34 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Call in the exterminator, be rid of them for good.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-10-2008, 03:17 AM   #6
Steel touching copper water pipes can lead to electrolysis. Over time this can destroy the integrity of copper piping.
dyier is offline   Reply With Quote
Old 02-10-2008, 07:14 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Actually, it is called a "Galvanic Reaction" or "Galvanic Corrosion".
In this case, the copper would be fine, it's the steel wool that would corrode.
http://www.fourseasonsroofingandsidi.../mixmetals.htm
- Build Well -
Old 02-10-2008, 07:42 AM   #8
You've never seen copper get holes where galvanized straps were used? The copper does suffer as a result.
Old 02-10-2008, 08:57 AM   #9
(the original)
Rewards Points: 756
Marlin, steel wool isn't galvanized. It's the zinc coating on galvanized straps or fittings that reacts with copper.
ratherbefishin' is offline   Reply With Quote
Old 02-10-2008, 02:16 PM   #10
Electrolysis is caused by the touching or mating of dissimilar metals. Doesn't make any difference what the metals are. Bronze and brass go well with copper, steel (galvanized or not) doesn't.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-10-2008, 03:31 PM   #11
Journeyman Plumber
Pest control is the best defense.
Old 02-10-2008, 03:54 PM   #12
Rewards Points: 150
First go around house and fix and PLUG all entrances for the critters getting in. Pay particuliar attention to things like wires entering,,,and dryer vents. IF you can stick a pensil erraser in the crack a mouse CAN and will enter.. I had a dryer vent with slinky vinyl flex hose,,,the mice crawled in the vent cause the lint didnt let the door close securely,,,then they chewed thru the hose and they were INSUDE the house. Replace with solid aluminum ducting,,,NO more mice.
Get repeating traps or just a bunch of regular ones and a piece of cheese and catch them all,,,they can multiply to alarming numbers INSIDE a house ,quickly!!
Have you ever heard of hauntavirus health concerns?? Have you ever heard of tick bourne infections from mice carrying ticks INSIDE your house?? Take ALL precautions necessary to protect the lives and health of YOUR family!!!(Plus about 30 other reasons for not cohabitating with MICE!!)
justdon is offline   Reply With Quote
Old 02-10-2008, 11:30 PM   #13
That's why I asked what he was trying to seal. He may well be trying to seal against a hose bib or something. If that was the case I was going to recommend a more perminant solution.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
PEX vs. Copper Aglease Plumbing 41 02-16-2010 06:14 AM
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 11:24 AM
wire next to copper plumbing pipes abc Electrical 6 02-02-2008 12:01 PM
difference b/ween L (blue - expensive) and M (red - cheap) copper pipes amakarevic Plumbing 4 07-31-2007 06:28 PM
