Steam Pipe Banging - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2011, 07:00 AM   #1
steam pipe banging
I inherited a situation where steam was brought to the third floor by a pipe connecting off the steam-feed to a second floor radiator.
When steam begins in the system, there is a period of loud banging in this pipe to the third floor.
The radiators are properly pitched for condensate to drain back in the one-pipe system. There is no such banging in other pipes, only in this pipe that was used to add a steam radiator to the third floor.
Any solutions? Is this a problem due to wrong size pipe-diameter to the third floor? How can problem be corrected? Thanks.
Amodeeo
amodeeo is offline   Reply With Quote
Old 09-08-2011, 07:50 AM   #2
Rewards Points: 1,536
Either the pipe is of too small a diameter or there is a "horizontal" section of pipe run that has a dip that collects water (condensate).
In some cases setting the radiator up on small blocks corrects the slope of the pipe under the floor but this usually does not work when the pipe runs perpendicular to and through the joists.
The Following User Says Thank You to AllanJ For This Useful Post:
amodeeo (09-08-2011)
Old 09-08-2011, 08:08 AM   #3
Learning by Doing
Leah Frances's Avatar
You need some better venting for the third floor - I have gotten lots of great advice about my steam heat from http://www.heatinghelp.com
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Driveway culvert to underground pipe zrooster99 Landscaping & Lawn Care 4 06-25-2011 12:42 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
One Pipe Steam Heat ? II Weeks HVAC 8 03-06-2010 07:54 AM
Single Pipe Steam Heat (Please help) jpic Plumbing 2 11-20-2008 07:51 AM
