Old 09-09-2009, 10:42 AM   #1
steam heat radiator
I want to change the valve on the side of my old radiators. Should I do it when there is no heat going thru, like the summer time? Does it matter?
Daniel52 is offline   Reply With Quote
Old 09-09-2009, 10:56 AM   #2
Remodeler
adpanko's Avatar
steam heat radiator
you most definitely do NOT want to do it while the the boiler is active and steam is moving through the system; so turn it off. As for whether you do it in summer or winter, it is up to you. I'd rather do it in summer when you don't need heat, and therefore aren't under the gun to get the thing changed quickly.
adpanko is offline   Reply With Quote
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Single Pipe Steam Heat (Please help) jpic Plumbing 2 11-20-2008 08:51 AM
Steam Heat - Radiator Enclosure Leah Frances HVAC 1 01-27-2008 02:49 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
