Old 12-21-2009, 09:00 AM   #1
Next Time...New Build
Steam Heat
I have a one pipe steam heat system in my current remodel. However, there is an addition on the back of the house that was put on a slab where the only heat now is from two vented wall units. They are of decent quality but they are an eyesore and I would ideally like to get rid of them.
My question, is it possible to tap one of the current steam lines from the main house and run a new radiator into the addition?
The good news is that everything is easily accessible in the main basement and the actual run for the new line would only be about 7 feet.
I know that there are pitch issues of the one pipe system but most importantly I wanted to see if this is even possible.
I will leave this task for a qualified plumber but I wanted to see if I should even waste my time.
Thanks in advance.
RickyBobby is offline   Reply With Quote
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Single Pipe Steam Heat (Please help) jpic Plumbing 2 11-20-2008 08:51 AM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 04:43 PM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
