STATE Water Heater Failures - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2013, 10:29 AM   #1
Rewards Points: 12
STATE water heater failures
Hello,
I just went through my 2nd STATE water heater in 7 years. Leaking internally. I called the manufacturer and because the 2nd water heater was a warranty replacement, they go off the install date of the first water heater. So even though the water heater is only 2 1/2 years old i'm SOL. F*** STATE WATER HEATERS! Rant over.
Anyway, it is a gas water heater and there is a water softener in the loop. The teenage girl on the phone at the manufacturer, who knows nothing about water heaters (ok, rant really over this time) suggested that the water softener was the cause of the problem. I am in Las Vegas and the water here is from the Colorado river and is really hard so I can't imagine that the water softener is harder on the equipment than straight city water. Although water heaters in these parts usually last through the waranty period, 2 1/2 years is very premature and abnormal.
Some other possibly useful information: 50 gallon residential, natural gas natural draft, only 2 adults live in house, house is only 7 years old.
So my question is, can a water softener really be that hard on a water heater? Or is there something else I can look at?
SinCityKid is offline   Reply With Quote
Old 05-02-2013, 10:36 AM   #2
Roofmaster
Rewards Points: 2,172
Did you pull the anode and look at it? Also, what is the water pressure in your home? What is your PH? State has been around for a long time. I agree with you, something is not right.
Old 05-02-2013, 04:02 PM   #3
Rewards Points: 582
alot of factors involved in why water heater fail...as mentioned ..ph. softner? pressure...expanison tanks.....more information is needed..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Javiles (05-02-2013)
Old 05-02-2013, 04:06 PM   #4
Rewards Points: 744
I'd check the condition of the anode first. On some, you may need to remove the top cover or cut a hole in it, to get to the top of the anode.
Seattle2k is offline   Reply With Quote
Old 05-02-2013, 06:08 PM   #5
Rewards Points: 12
Anode wasn't too bad. When I drained the water heater there was hardly any sediment that came out which is rare around here. Then toward the end of draining the tank tthere was quite a bit of rust, at least I think it was rust. Other than that the thing looked brand new still.
Old 05-02-2013, 10:22 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 994
Many years ago i did warranty work for the old Mor Flo water heaters a cheap water heaters as standard go, i found that 90 percent of the failure where installation related. I still use state every once in a while, no call backs as of today.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 05:44 PM
Best practices for Water Heater install? simanco Plumbing 4 08-22-2012 11:36 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
