State Industries Water Heater 1988 - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2013, 12:46 PM   #16
Sycamore Inn's Avatar
Rewards Points: 87
Since owning this home it appears that Dot was good with maintenance. The water heater looks like the copper tubing has been replaced and possibly the anode. The anode has plastic tape over the top. I placed new electrical tape on the insulation but thats it. Laying on the ground next to the water heater was this pipe. Was the pipe part of the water heater and possibly replaced? Can I discard it?
Thanks for the input.
State Industries Water Heater 1988-imag0680.jpg   State Industries Water Heater 1988-imag0686.jpg
Sycamore Inn is offline   Reply With Quote
Old 09-22-2013, 01:18 PM   #17
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
The TP (Temperature/Pressure) release valve on the right side of the tank should be piped to a drain (or minimally within 6 inhces of the floor).
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-22-2013, 01:30 PM   #18
Rewards Points: 87
It's piped into the back wall I assume that is a drain?
Water heater problems- thought I fixed the problem- what do I do next? brandall Plumbing 23 04-19-2013 06:44 PM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
