State Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2010, 08:58 PM   #1
I have two State 80 gallon hot water heaters that I installed parallel with each other. The power source for each one feeds from different panels. These units were installed in my lake house last summer and have always tripped the breaker in the panels or the high limit switch on both tanks. I have attempted to shut off each tank at separate times to trouble shoot and they both still do the same thing? Any idea on what it could be?
Khawkins is offline   Reply With Quote
Old 03-11-2010, 09:05 PM   #2
What size wire & breakers feed each ?
What does the Mfg require ?
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Khawkins (03-11-2010)
Old 03-11-2010, 09:08 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, to the breaker:
what is the element wattage and what size breaker are they on.
to the high limit: the only reason it trips is if the water gets too hot so I would try setting the t-stats down to 100 or so to see what is happening. If one of the thermostats is not shutting down, it will over heat the water and trip the high limit.
do you have a voltmeter to be able to tell when a t-stat is calling for heat?
Old 03-11-2010, 09:17 PM   #4
The units are setting about 10' from the panels and have #10 wire feeding them. The breaker is a 40amp breaker
Old 03-11-2010, 09:18 PM   #5
Yes, I do have a voltmeter
Old 03-11-2010, 09:19 PM   #6
nap
You talking to me?
nap's Avatar
what is the wattage of the heaters?
and the voltage being used?
Old 03-11-2010, 09:22 PM   #7
the heaters are both single phase 240 heaters
Old 03-11-2010, 09:29 PM   #8
nap
You talking to me?
nap's Avatar
and the wattage?
and could you clarify something:
You don't mean that the water heater that the breaker is off is still a problem when the breaker isn't on, right?
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 11:13 PM
Water Heater Troubles deadguydrew Plumbing 9 10-19-2008 10:30 AM
"sticky" gas water heater thermostat homer12 Appliances 8 01-25-2008 05:36 PM
