-   -   State Hot Water Heater (http://www.diychatroom.com/f7/state-hot-water-heater-66588/)
Khawkins 03-11-2010 08:58 PM
I have two State 80 gallon hot water heaters that I installed parallel with each other. The power source for each one feeds from different panels. These units were installed in my lake house last summer and have always tripped the breaker in the panels or the high limit switch on both tanks. I have attempted to shut off each tank at separate times to trouble shoot and they both still do the same thing? Any idea on what it could be?
Scuba_Dave 03-11-2010 09:05 PM
What size wire & breakers feed each ?
What does the Mfg require ?
nap 03-11-2010 09:08 PM
well, to the breaker:
what is the element wattage and what size breaker are they on.
to the high limit: the only reason it trips is if the water gets too hot so I would try setting the t-stats down to 100 or so to see what is happening. If one of the thermostats is not shutting down, it will over heat the water and trip the high limit.
do you have a voltmeter to be able to tell when a t-stat is calling for heat?
Khawkins 03-11-2010 09:17 PM
The units are setting about 10' from the panels and have #10 wire feeding them. The breaker is a 40amp breaker
Khawkins 03-11-2010 09:18 PM
Yes, I do have a voltmeter
nap 03-11-2010 09:19 PM
what is the wattage of the heaters?
and the voltage being used?
Khawkins 03-11-2010 09:22 PM
the heaters are both single phase 240 heaters
nap 03-11-2010 09:29 PM
and the wattage?
and could you clarify something:
You don't mean that the water heater that the breaker is off is still a problem when the breaker isn't on, right?
