Standing Water In Washer Outlet Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2011, 11:02 AM   #1
Standing water in washer outlet hose
I have a Frigidaire front loader. Between washes I notice a sulpher type odor from the outlet hose at the back of the machine. This hose is a flex type and there is a large section that lies flat on the floor behind the machine before it turn upwards to be inserted into the stand pipe.
Can I shorten this hose without damaging anything or is there another fix?
my61dublin is offline   Reply With Quote
Old 08-11-2011, 11:38 AM   #2
Rewards Points: 1,418
You will never get rid of all of the standing water in the hose.
If you can detach the hose from teh washer completely you might try flushing it out to get rid of any accumulated lint or debris.
You can shorten the hose but that is not good. It would be troublesome to splice it back together if you need to relocate or sell the washing machine. Many drain hoses are corrugated in a way that makes it difficult to use a coupling and hose clamps.
Better would be to re-arrange the hose so most of the extra length is higher than the top of the stand pipe.
Do not splice on to a washing machine or dishwasher hose longer than it was originally and do not seal it to the stand pipe.
Old 08-11-2011, 12:45 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
your hose should not be lying on the floor. Your machine should have a hose clip at the very top of the washer to hold it up. Clip it into the holder and then over to the drain.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-11-2011, 10:21 PM   #4
Standing Water in washer outlet hose
Thank you for your replies. I took a look at the back of my washer and there is no clip so I will see if I can find on that can be attached now. I always felt it should not be on the floor but with no hints about the clip thing couldn't see anyway to get it up off floor. Thanks again...much apprecaietd help
Water damage in laundry room re: clothes dryer outlet mcbutterpants Electrical 3 02-07-2011 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 01:52 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
