Standing Water In Sewer Trap - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2014, 02:02 PM   #1
Rewards Points: 6
Standing Water in Sewer trap
Hey guys,
I need a little advice, and was hoping some of you might be able to share your expertise. I have a split level house and I noticed there is standing water in the sewer trap. Does anyone know if this is a big issue and what recommendations you might have for a fix?
Any advice would be GREATLY appreciated.
Dandar is offline   Reply With Quote
Old 10-31-2014, 02:57 PM   #2
Rewards Points: 252
If i'm understanding you correctly, there's supposed to be water in the trap, to block the sewer gas from entering the home.
All traps have standing water in them for this reason. Now if water is backing up and coming out of the drain, then that's a different story.
Please wait for the plumbers to respond. Thanks.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
gregzoll (10-31-2014)
Old 10-31-2014, 03:14 PM   #3
joed's Avatar
Rewards Points: 12,460
I can't tell from the picture but if you have standing in the hole around the pipes that is not good. If it is sewage water then it is really bad. You have a sewer leak that needs to be repaired. If it is ground water then there should be some sort of drainage that takes it away, a sump pump or weeping tile system.
The Following 3 Users Say Thank You to joed For This Useful Post:
Dandar (11-03-2014), gregzoll (10-31-2014), jmon (10-31-2014)
Old 10-31-2014, 05:19 PM   #4
Rewards Points: 13,472
Not even seeing a trap in that picture.
Just old style cast iron that's going to fail at some point and the wrong style Tee.
Dandar (11-03-2014)
Old 10-31-2014, 05:58 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,084
Ayuh,.... I think what's bein' called a Trap, is the Sump Pit,......
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
Old 10-31-2014, 06:36 PM   #6
Rewards Points: 252
Now it makes sense. Thanks Bondo.
Still don't know if it's sewage or water he's seeing. Once we know for sure, joed, post 3, suggestion makes the most sense.
Dandar (11-03-2014)
Old 11-03-2014, 09:53 AM   #7
Rewards Points: 6
Much appreciated for the responses! Its definitely not sewage, and seems to be ground water. I'll let you guys know how we decide to proceed.
The Following User Says Thank You to Dandar For This Useful Post:
jmon (11-03-2014)
Old 11-03-2014, 06:02 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 568
If you look closely at the picture- it looks like a house trap to the outlet side of the clean out riser. To the right of the trap and riser appears to be a small sump pump.
So, I'd say you have a pit there to handle the ground water. It just happens to have a drain line running through it.
Research that pump some to see if it even works....
The Following User Says Thank You to TheEplumber For This Useful Post:
Dandar (11-10-2014)
Old 11-03-2014, 06:56 PM   #9
joed's Avatar
Even if the pump works there will still be some water in the pit.
The Following 2 Users Say Thank You to joed For This Useful Post:
Dandar (11-10-2014), TheEplumber (11-03-2014)
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
water main whine related to main sewer line? denemante Plumbing 4 03-07-2013 09:14 PM
Trap on main sewer line? mazzonetv Plumbing 3 12-03-2012 03:20 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
