Standing Water/Overflow After Snaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2012, 12:58 PM   #1
Rewards Points: 93
Question
My kitchen sink was back up after the trap and had a professional come out and snake the drain. He pulled out some nasty stuff and after that the flow was fine and no more clogged/slow drain.
3 hours later I went into my laundry/mud room where our HVAC unit is and the floor drain was overflowed! That has never happened to us (but we have only owned the house since May). There is a PVC pipe that goes to the floor drain that is from the HVAC unit but that is just drips at a time. I look into the floor drain and 6 to 8 inches down there is standing water.
What could have happened after the drain in the kitchen was snaked? Could it have clogged this or is standing water normal in the floor drain? Do I need him to come back out to snake that floor drain? My wife took a shower and so did I last night and flushed all the toilets (3) in our house and the water did not go up or down in the floor drain.
Any help would be great.
NOTE: I do have to say I dont remember if when we moved into the house if there was standing water.. I did not look and dont remember what the inspector said. The floor drain does not have washing machine water pouring into it from the top.
Thanks!
7 VII 7 is offline   Reply With Quote
Old 08-03-2012, 01:54 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If theyre tied into same line before the main it could have shoved something further down line.
Does water in floor drain get higher when running the sink?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
gregzoll (09-07-2012)
Old 08-03-2012, 02:01 PM   #3
Rewards Points: 93
I am running the AC, sink, dishwasher AND washing machine at the same time right now. I will report back.
Old 08-03-2012, 02:07 PM   #4
plummen's Avatar
The condensate from ac drain shouldnt be a big enough load to notice,the sink/dishwasher normally dump into same drain .
Washing machine should be on its own line back to the main
Old 08-03-2012, 02:08 PM   #5
Rewards Points: 93
That is correct but my wife had laundry to do and it is 94 degrees here lol
Old 08-03-2012, 02:17 PM   #6
plummen's Avatar
Id isolate the loads from eachother to see which one affects it more .
Does anything happen if you flush a toilet in that area?
Old 08-03-2012, 03:21 PM   #7
Rewards Points: 93
Ok, I ran everything and the water level did not move an inch. Not sure why it overflowed when he did the snaking of the kitchen sink/drain.
Picture of it in my laundry room
Picture of the water level, you can see it is about 8 inches below the top. Standing water.
Old 08-03-2012, 04:47 PM   #8
plummen's Avatar
There needs to be a certain amount of water above the trap for it to seal good.
Id try hitting it with a good plunger and see if it helps
Old 08-03-2012, 11:07 PM   #9
Rewards Points: 352
The water in the floor drain is supposed to be there it is trapped like under your sink. It sounds like it backed up while the plumber saw cabling it. If all your drains are running now then you are cool
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
drtbk4ever (09-07-2012)
Old 08-04-2012, 05:15 PM   #10
Rewards Points: 93
So I have ran some more dishes, showered, ran the sink and running the outside hose to water the lawn... looks like I am good. Weird but I will keep an eye on it. Cool thing the plumber gave me a 6 month "warranty" on his work and labor
Thank you guys VERY much!
The Following User Says Thank You to 7 VII 7 For This Useful Post:
ben's plumbing (08-04-2012)
Old 08-04-2012, 08:43 PM   #11
plummen's Avatar
Thats one hell of a warranty on cleaning a drain,around here most sewer/drain guys give you 30 days if youre lucky!
Old 08-05-2012, 01:38 PM   #12
Rewards Points: 93
Well I asked him and he said since it is just the kitchen drain he said 6 months.. so I did not argue
Old 09-06-2012, 08:25 PM   #13
Rewards Points: 93
Well over the last month or so it has been fine. It has gotten up to the top level of the floor but never overflowed.... Until tonight
The AC has been running but nothing too crazy. Why is this happening again? Should I call a plumber ASAP?
Old 09-06-2012, 08:42 PM   #14
DIY staff
Rewards Points: 7,174
Before you call n the troops---clean out that floor drain---a simple snake for $10 or less is what you need---often the P-trap gets clogged with lime and floor sweepings----rod it and flush with a pail of water---see if it will take that water---If not---call in your friendly plumber---
Old 09-07-2012, 07:43 AM   #15
Rewards Points: 93
I took a look this morning and it is low again. Not sure what to do now... should it just be a "live with it" thing?
Tags
clogged , drain , snake
How to get a switch to power ON/OFF a standing lamp? Metallo Electrical 8 02-14-2011 04:25 PM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
standing seam over purlins hawaiidiy Roofing/Siding 5 11-21-2009 07:00 PM
DIY Standing Seam Roof stubits Roofing/Siding 5 05-14-2009 10:58 AM
Standing liquid in cleanout TheOldMan Plumbing 1 12-11-2008 02:15 PM
