-   -   Standing Water/Overflow After Snaking (http://www.diychatroom.com/f7/standing-water-overflow-after-snaking-152458/)
7 VII 7 08-03-2012 01:58 PM
My kitchen sink was back up after the trap and had a professional come out and snake the drain. He pulled out some nasty stuff and after that the flow was fine and no more clogged/slow drain.
3 hours later I went into my laundry/mud room where our HVAC unit is and the floor drain was overflowed! That has never happened to us (but we have only owned the house since May). There is a PVC pipe that goes to the floor drain that is from the HVAC unit but that is just drips at a time. I look into the floor drain and 6 to 8 inches down there is standing water.
What could have happened after the drain in the kitchen was snaked? Could it have clogged this or is standing water normal in the floor drain? Do I need him to come back out to snake that floor drain? My wife took a shower and so did I last night and flushed all the toilets (3) in our house and the water did not go up or down in the floor drain.
Any help would be great. :thumbup:
NOTE: I do have to say I dont remember if when we moved into the house if there was standing water.. I did not look and dont remember what the inspector said. The floor drain does not have washing machine water pouring into it from the top.
Thanks!
plummen 08-03-2012 02:54 PM
If theyre tied into same line before the main it could have shoved something further down line.
Does water in floor drain get higher when running the sink? :)
7 VII 7 08-03-2012 03:01 PM
I am running the AC, sink, dishwasher AND washing machine at the same time right now. I will report back.
plummen 08-03-2012 03:07 PM
The condensate from ac drain shouldnt be a big enough load to notice,the sink/dishwasher normally dump into same drain .
Washing machine should be on its own line back to the main :)
7 VII 7 08-03-2012 03:08 PM
That is correct but my wife had laundry to do and it is 94 degrees here lol
plummen 08-03-2012 03:17 PM
Id isolate the loads from eachother to see which one affects it more .
Does anything happen if you flush a toilet in that area? :)
7 VII 7 08-03-2012 04:21 PM
Ok, I ran everything and the water level did not move an inch. Not sure why it overflowed when he did the snaking of the kitchen sink/drain.
Picture of it in my laundry room
http://i48.tinypic.com/34siama.jpg
Picture of the water level, you can see it is about 8 inches below the top. Standing water.
http://i45.tinypic.com/142x69w.jpg
plummen 08-03-2012 05:47 PM
There needs to be a certain amount of water above the trap for it to seal good.
Id try hitting it with a good plunger and see if it helps :)
plumberinlaw 08-04-2012 12:07 AM
The water in the floor drain is supposed to be there it is trapped like under your sink. It sounds like it backed up while the plumber saw cabling it. If all your drains are running now then you are cool :)
7 VII 7 08-04-2012 06:15 PM
So I have ran some more dishes, showered, ran the sink and running the outside hose to water the lawn... looks like I am good. Weird but I will keep an eye on it. Cool thing the plumber gave me a 6 month "warranty" on his work and labor :)
Thank you guys VERY much!
plummen 08-04-2012 09:43 PM
Thats one hell of a warranty on cleaning a drain,around here most sewer/drain guys give you 30 days if youre lucky! :)
7 VII 7 08-05-2012 02:38 PM
Well I asked him and he said since it is just the kitchen drain he said 6 months.. so I did not argue :)
7 VII 7 09-06-2012 09:25 PM
Well over the last month or so it has been fine. It has gotten up to the top level of the floor but never overflowed.... Until tonight
http://i.imgur.com/JUkkp.jpg
The AC has been running but nothing too crazy. Why is this happening again? Should I call a plumber ASAP?
oh'mike 09-06-2012 09:42 PM
Before you call n the troops---clean out that floor drain---a simple snake for $10 or less is what you need---often the P-trap gets clogged with lime and floor sweepings----rod it and flush with a pail of water---see if it will take that water---If not---call in your friendly plumber---
7 VII 7 09-07-2012 08:43 AM
I took a look this morning and it is low again. Not sure what to do now... should it just be a "live with it" thing?
