Standard Toilet Flange Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2008, 05:57 PM   #1
standard toilet flange location
I am putting a bathroom in my basement, and about to install the flange. From reading posts here, I saw 10, 12, or 14 inch rough ins. What is the most used distance, and then, is it measured from the finished wall or the finished studs? Also, since I will be putting tile down, should I install the flange on top of the backer board?
Thanks in advance
SR996 is offline   Reply With Quote
Old 12-03-2008, 10:15 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
It depends on the toilet that you plan to install, but the most used distance is 12" on center from the finished wall.
For the best wax ring seal results, the toilet flange should be installed on top of the finished tile floor level with only the thickness of the flange itself above finished tile floor level, and bolted securely to it with the upright toilet bolts at 9 o'clock and 3 o'clock.
If you're bolting the flange down to wood, then lag screws work well. If you're bolting it down to concrete, then Tapcons work well.
Good Luck!
Mike Swearingen is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
Toilet flange floor advice Hobb3s Plumbing 6 04-15-2008 09:41 AM
