Standard Toilet Bowl Floor Plan - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2012, 08:28 PM   #1
Rewards Points: 1,062
Question
standard toilet bowl floor plan
i am not being successful using Google to find a multilayered floor plan of a toilet bowl that shows the position of the sewer hole in the bottom in perspective of the bowl and the seat above it.
in other words, i am trying to project where the bounds of the bowl/seat will be on the cement board around the existing flange. the reason i am trying to do that is to determine the optimal position of the TP holder (go ahead and laugh).
can anybody point or attach a floor plan that would help me draw these contours on my floor and simulate the positioning?
thanks
Old 04-27-2012, 08:51 PM   #2
Rewards Points: 636
why not install toilet then sit on lid and hold tp holder on wall till you get that perfect spot
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-27-2012, 09:16 PM   #3
excellent question. the reason is that i like to put a horizontal 2x4 in the back where it will hang in order for the holder to be fastened into it through the cement board and not just screwed in the cement board. another reason is that the holder, due to its design, may have to be installed before tile, with tile going around
Old 04-27-2012, 11:37 PM   #4
Rewards Points: 13,300
Ok so what's your point? I've set a toilet in place with nothing on the walls, sat on the toilet and pretended to reach for the roll to figure out where to put the backer.
It's not going to matter if it's off by a few inches.
Old 04-27-2012, 11:48 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Toilet sits roughly 15" off the floor.
The front of a toilet sits roughly 30" from the rear wall.
Put 2x8 all over the place in the area that you THINK the toilet paper holder should go and you will be close enough.
Journeyman Plumber
Old 04-28-2012, 10:21 AM   #6
Rewards Points: 636
just dry set toilet if that big of a concern and sit on it and get that perfect tp spot. just remember to remove toilet before someone else uses toilet.
Old 04-28-2012, 10:49 AM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
Go to a showroom at a plumbing wholesaler. Ask to see a spec sheet for your toilet. They should have them.
Old 04-28-2012, 11:18 AM   #8
concretemasonry's Avatar
Rewards Points: 2,578
Just do yourself a favor and get a "comfort height" toilet. You will never regret it. After that sit there and figure out where you want the tp holder.
Dick
concretemasonry is offline   Reply With Quote
Tags
floor plan , toilet bowl
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 02:31 PM
Toilet bowl setting compound? djgrant Plumbing 12 06-07-2011 10:16 PM
Toilet bowl losing water czars Plumbing 2 10-28-2010 08:56 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Moisture On Toilet Bowl Grout jte1130 Plumbing 2 02-05-2008 08:25 AM
