Stand Up Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 06:32 AM   #1
Stand up shower
I have a stand up shower with leaking pipe behind wall (that goes to the shower head) Can't get to it from below or behind do I have to cut through the tub lining from the shower head down to fix it? I think it froze because the control cartridge broke in half.
tpob117 is offline   Reply With Quote
Old 01-08-2010, 07:07 AM   #2
What's behind it?? can't you cut the wall out behind it??
SULTINI is offline   Reply With Quote
Old 01-08-2010, 09:04 AM   #3
Rewards Points: 150
is this against a outside wall? if not i would rather patch sheet rock then fiber glass or tile.
rudolph58 is offline   Reply With Quote
Old 01-08-2010, 10:14 AM   #4
stand up shower
stairs leading to basement, you can see the incoming pipes in basement ceiling leading to back of shower. Going down the stairs there is sheet rock above, but that seems far away from the shower.
Old 01-08-2010, 10:26 AM   #5
Rewards Points: 150
i see no picture attachments
Old 01-08-2010, 02:03 PM   #6
1ST floor 2ND floor where is it????
How bout them cellar steps tell us a little bit about it.?.?.
Old 01-08-2010, 02:19 PM   #7
stand up shower
Its a summer camp that was an old motel office that was razed (1980's) and moved lakefront. The shower/bathroom is on the first floor above the basement. The stairs go down about 5ft until you are under the shower pipes. The sheet rock is at about 4 ft down the stairs and above your head. I have no photos as I am 2+hrs away ( but will try to provide on next trip up)
Old 01-08-2010, 04:10 PM   #8
Sounds like you might have to build scaffold on the steps to get at the pipings behind the shower.
Can't say for sure need more info .
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
