Old 06-14-2007, 05:50 PM   #1
stainless sink/countertop for food co-op
Hi,
I'm getting started on a project that involves a bit of remodeling of the back of my local food co-op. I'm going to need a couple pieces of stainless steel countertop, including a sink. Not a top-installed sink, but a sink that is actually part of a countertop. I've been poking around on the internet for a bit trying to figure out where I could purchase such a thing, and I'm not having a lot of luck. I did see that on specialtystainless.com, I could get what I'm looking for custom-made for probably around $1500. I really don't think I should need to spend nearly that much--I'm hoping that there are pre-made things out there somewhere that could cost maybe a third of that? Can anyone point me in the right direction?
Thanks!
Dan O
arise is offline   Reply With Quote
Old 06-15-2007, 11:27 AM   #2
You could try looking at auctions of restaurant equipment. There might be some online under that category.
Gerry
Gerry Kiernan is offline   Reply With Quote
More On This Topic
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
Today we’re going to be redoing an older home sink and installing it. It has some rust around here, and more or less the drains are still really tight. You need to clean it with ajax first, and then we’re going to install the faucet first. So... Read More »
I’m Lee. I have a degree in architecture and about ten years in the construction field and today we’re doing a fairly ornate countertop in my own house. Both of the countertops are using the basic same colors, but it’s a different tile... Read More »
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
Gauge of stainless steel sink Not Sure Plumbing 2 08-29-2006 05:56 AM
Stainless chimney liner relining systems Lisalovespainting HVAC 2 08-09-2006 06:48 AM
Dented stainless steel-HELP!!! yrapps Remodeling 4 05-09-2006 05:22 PM
PVC to Stainless econdave Plumbing 3 05-02-2006 06:58 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
