Old 01-31-2009, 10:51 PM   #1
Stack Distance From Toilet
I'm redoing the drain pipe in a second floor bathroom. I am wondering if 10-15' is too far for a toilet to be from a stack? I am using 4" PVC pipe and a sink, bath tub and washing machine drain will be connected to the stack.
With my current plan, the bath tub would have a horizontal run of 15', the toilet 13', the sink 10' and the washer 5'. Are any of these runs too far? This is basically how it was before except for the toilet which I am moving during the redesign.
Thanks for the help.
jonathan03 is offline   Reply With Quote
Old 02-01-2009, 07:55 AM   #2
By stack do you mean a wet vent? We try to run a vent within 5 feet of any drain.
II Weeks is offline   Reply With Quote
Old 02-01-2009, 12:57 PM   #3
By stack I mean the vertical pipe that runs from the floor to the roof and is open at the roof. I'm not sure what a wet vent is since I'm a DIY plumber hehe. We may be talking about the same thing. If the toilet is 12' from the vertical stack pipe, is that an issue?
Right now the person who did the job before has the bath tub 15' from the vertical stack. However, they ran a smaller 2" vertical pipe about 4" from the bath tub up into the next floor and tied it in the main 4" vertical stack.
I'm doing a complete remodel and need to know how to properly vent the toilet, bath tub, sink and laundry room. Is a 15' horizontal branch from the main 4" stack pipe too far? Can a toilet right next to a sink and bath tub use the same drain pipe?
Old 02-01-2009, 09:57 PM   #4
take a few minutes out and give us a quick drawing on what you ahve and what you want to do.
Its a lot easier to help out that way and the way they used to do plumbing is a little different today.
Old 02-02-2009, 05:39 AM   #5
Ok here is my sketch, not the best I know but Paint isn't very good for this. I know you need a trap for both the tub, sink and washer, but not sure how to make it in paint.
Here are my questions:
1) Is the toilet too far from the main vent stack?
2) Is 4" pipe overkill for the horizontal run to connect the tub, toilet, sink and washer to the main vent stack?
3) For the washer, I plan to run a vertical pipe with a trap that connects to the main horizontal run. Its that ok?
4) Can the main 4" vertical vent stack to the roof be inside an exterior wall?
Old 02-02-2009, 06:43 PM   #6
The whole bathroom group is to far from vent stack to properly vent the toilet lav, and shower, I would wet vent that group with your lav, but instead of what you drew, I would hit the toilet last and as you branch of to hit your lav throw in a 2x2 wye before your 90 for the lav and shoot it over to the shower.
zosoplumber is offline   Reply With Quote
Old 02-02-2009, 06:44 PM   #7
And yes 4" is over kill i would run 4" up tp the washer and then bushing down with a 3x4 bushing.
Old 02-02-2009, 07:16 PM   #8
Thanks for the reply.
So you think the whole branch from the main vent stack with the tub, toilet, sink, and washer could be 3"?
How thick should the vent pipe for the toilet be? Can I run it into the main 4" vent to the roof? The reason why I want to run the vents like this is so I don't have to move the output of the pipe to the roof. I have a 3 story tin roof which complicates things.
If I do the things in this sketch, can I keep the toilet where it is? The washer will be a separate room. There is really a wall between the sink and washer to divide the bathroom and laundry room that I didn't show.
Old 02-02-2009, 07:37 PM   #9
that looks better and keep in mind that vent pipes need to be pitched as if it were a drain pipe.
More On This Topic
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Hello again. Well, before we get going with our cleaning, we have to gather our supplies. And ordinarily, I would do this kind of cleaning in the bath tub or in the sink. Some of these instruments are a little big for the sinks, so I use it in the bath... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet - Wall Distance Pineapple Plumbing 3 11-03-2008 01:10 PM
wye distance from stack ridgian Plumbing 4 02-04-2008 12:13 PM
Distance to stack rusty_5620 Plumbing 4 02-22-2007 12:39 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
