Squealing Water Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2012, 09:27 PM   #1
Rewards Points: 33
Squealing water pipes
Recently, right about the time I turned on my outside hose bibs, as well as my irrigation system, the pipes in my house started squealing something fierce. The problem goes away as soon as I so much as turn on a trickle of hot or cold water, at any faucet in the house. The sound seems to be coming from the area of my natural gas hot water heater.
Anyway, I googled and found several suggestions, including:
  • bad cistern inlet valve in a toilet tank
  • bad vacuum breaker in an outside hose bib
  • leaky irrigation system
  • leak in an outside faucet
So, I turned off the valves to both outside hose bibs. And the valve to the irrigation system. And, I turned off the valves on all the toilets. Still, I get the high-pitched squealing that instantly stops if I open a faucet at any sink.
The wife said that neither the dish washer nor the washing machine seems to stop the squealing if they were in use, but any faucet will instantly stop the noise.
What in the world could it be?
Larry
kennelm is offline   Reply With Quote
Old 04-16-2012, 09:35 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
What is your water pressure? You can get a pressure gauge that connects to any hose connection (hosebib, laundry tub faucet, etc). May not be the problem, but it's where I would start since the problem persists after you've turned the irrigation and hosebibs back off.
JDC is offline   Reply With Quote
Old 04-16-2012, 09:40 PM   #3
Rewards Points: 33
I don't have a pressure gauge. Sounds like trip to Sears or Lowes is in my future. What is a normal reading?
Old 04-16-2012, 09:48 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
The absolute highest, in theory, is 80psi. I usually set pressure reducing valves at 60 psi and have no complaints from my customers. Extreme high pressure can cause squealing pipes. You can pick up a pressure gauge and most any hardware store for around $10 or so. If you find your pressure to be high and you have a pressure reducing valve, then that of course indicates its time for a new one. You'd most likely find your PRV near where the water main enters the house.
Old 04-17-2012, 06:37 AM   #5
Rewards Points: 1,512
Is the squealing associated with one particular faucet or hose bibb being on? If you turn that faucet on higher does the squealing go away?
Any unusual low pressure problem for that faucet?
AllanJ is online now   Reply With Quote
Old 04-17-2012, 07:10 AM   #6
Rewards Points: 33
There is no particular faucet that I can link to the problem.
A couple months ago we did have an issue with a shower that had substantially reduced pressure. I took the cartridge out and some debris spilled out when I flushed the line. I put in a new cartridge (it was like $35 at Lowes) and the pressure returned to normal, as far as I can tell. Wonder if this could be related?
Old 04-17-2012, 09:33 AM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'd say check out the water heater. Does it have an expansion tank on it? Sometimes they can be noisy or maybe it's bad, and you're hearing what little air is left in it being absorbed by the water and the water squeezing through the air bladder...
Might be a longshot, but I check mechanical devices first.
Journeyman Plumber
Old 04-17-2012, 07:15 PM   #8
Rewards Points: 582
if you have a pressure reducing valve at meter sometimes these can make a squealing noise if they need cleaned....
Old 04-21-2012, 12:02 PM   #9
Rewards Points: 33
Solved
So, I had a plumber come out. He found that the relief valve? on the hot water tank was bad, and was letting a steady flow of water spill off into the sump pump. He replaced that with an expansion tank.
I have noticed that the sump pump was dumping more water than usual outside, so maybe this was why. Anyway, the squealing has stopped.
Old 04-21-2012, 12:09 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 674
Originally Posted by kennelm View Post
So, had a plumber come out. He found that the relief valve? on the hot water tank was bad, and was letting a steady flow of water spill off into the sump pump. He replaced that with an expansion tank.
More likely, he replaced the relief valve and added an expansion tank.
You might find an increase in your water bill too because of the faulty valve.
Old 04-21-2012, 12:16 PM   #11
Rewards Points: 33
Right. That's what I tried to say in my last post.
Actually, I am expecting the water bill to go down now that the faulty valve is not wasting water.
Old 04-21-2012, 12:37 PM   #12
Plumber
Rewards Points: 674
Ha, that's what I was trying to say in my last post
Old 04-21-2012, 09:44 PM   #13
Doing it myself
Alan's Avatar
"That's what I'm saying to YOU!"
http://attrition.org/security/rant/f.../dodgeball.gif
Journeyman Plumber
Old 04-22-2012, 08:06 AM   #14
Rewards Points: 33
Originally Posted by Alan View Post
Bonding water pipes WillK Electrical 14 06-14-2011 06:14 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot Water Pipes Making Noise kubichekb Plumbing 2 02-12-2010 10:41 AM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
