Squealing Noise When Water Pipes Shut Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2008, 06:45 PM   #1
Squealing noise when water pipes shut off
Just opened the valve to the outside faucet. Now all pipes - washer, toilets etc, make a squealing noise when the water shuts off.
HELP!!!
wrencho is offline   Reply With Quote
Old 05-12-2008, 01:50 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like you may just have a faulty water inlet valve in a toilet tank. Turn the water off to each toilet one by one to find it, and then replace the valve with a Fluidmaster 400A float-cup type. They are very inexpensive and have easy illustrated installation directions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-12-2008, 11:01 PM   #3
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Wrencho,
Something else to check is wheter or not you have a vacuum breaker attached to the hosebibb (the faucet). This will be a brass fitting that is screwed onto the hosebibb where the hose attaches. It is designed to prevent water from flowing back into your house system in the event of a problem. Sometimes a bad vacuum breaker will cause a loud whine or hum hroughout the water system when something is running.
If your hosebibbs have the vacuum breakers attached, temporarily removing them will let you find out if this is the problem. If so, just get some new ones and screw them on. The old ones may have a set screw in them which will need to be drilled out in order to remove them. This is fairly simple to do, just don't drill too deep.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
PVC Pipes Pop And Click When Water Runs jasonsullivan Plumbing 3 01-16-2008 03:41 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 07:20 PM
water pipes make noise after use eric Plumbing 2 09-25-2007 03:32 PM
Strange noise associated with hot water - New Question johnny Plumbing 2 08-26-2007 09:40 AM
