Sprinkler Valves Not Quite - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2012, 09:01 AM   #1
Rewards Points: 290
Sprinkler valves not quite
Recently I have done a coppe repiping and since then I have observed this problem.
When the sprinklers watering is done, the valves are getting closd very hard.. making big noise. I am worried this may damage the valves or the sprinklers.
The connection to these valves is not changed due to coppe repiping. The connection to the sprinkler values is directly from the city water line ,, it means - it is before the pressure regulating valve. The city water pressure is obviously high.
But why this problem now ? Any thoughts ?
cprao is offline   Reply With Quote
Old 04-15-2012, 10:33 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by cprao View Post
......The city water pressure is obviously high......
How High? I would first get one of these:
http://www.amazon.com/Rain-Bird-P2A-...4501168&sr=8-1
This one goes to 200 PSI my old one only went to 100
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-15-2012, 10:41 AM   #3
Rewards Points: 14,026
http://www.mrdrip.com/pressureregulators.htm
Old 04-15-2012, 04:06 PM   #4
Rewards Points: 290
It is 120 PSI. This is directly connected to sprinkler valves. Should I be adding a pressure regulator here ?
Old 04-15-2012, 09:33 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 834
Your house should be below 80 psi- preferably 60 psi
you probably should lower the sprinkler pressure too. A lot of the piping used for irrigation is not rated for extremely high pressure.
But that may not eliminate the water hammer. Quick closing valves like irrigation solenoid valves attribute to water hammer. Perhaps your water supplier has recently boosted pressure?
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (04-16-2012)
Old 04-15-2012, 10:58 PM   #6
Rewards Points: 290
My house is set for 80.
What is the way for me to avoid quick closure of values ?
Old 04-15-2012, 11:04 PM   #7
You can't change the speed of the valves closing but you could install water hammer arrestors. They cushion the effects of water hammer caused by the quick closing valves.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
TheEplumber (04-15-2012)
Old 04-16-2012, 03:31 AM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Wow,thats a lot of pressure on any kind of valve.
Id have a reducer installed on there,is there a back flow preventer on the system?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-16-2012, 04:56 AM   #9
Tool Geek
PaliBob's Avatar
Originally Posted by VIPlumber View Post
.......but you could install water hammer arrestors. .......
They look similar to this:
http://www.amazon.com/Mini-rester-Wa.../dp/B000JRCFHK
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-16-2012, 05:02 AM   #10
Too Short? Cut it Again!
Definitely put some pressure regulation in place for those irrigation valves.
Any advantages between sprinkler valves? s-one Landscaping & Lawn Care 4 05-12-2011 09:15 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Do I need to raise my irrigation valve(s)? MrSmythe Landscaping & Lawn Care 3 09-03-2010 06:01 PM
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
locating buried sprinkler valves MrLinux Landscaping & Lawn Care 3 08-15-2009 12:50 AM
