Sprinkler Valves Leak Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2013, 03:50 PM   #1
Rewards Points: 276
sprinkler valves leak replacement
I have 3 questions
1) the sprinklers valve all leak on the bottom (left side of pic) where the PVC fitting threads up into the valve. Is my only option to cut them off and glue on the replacement fittings that I first thread into the new valve with plenty of tape?
2) the ball valve in the picture is not shutting off the water completely.
How can I glue in a new valve?
3) how high do the valves need to be and is the blue glue drip make the pipe unusable for gluing a new coupling?
DIYGST is offline   Reply With Quote
furnace replacement and evaporator coil leak Armylis HVAC 4 10-02-2012 09:04 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 09:21 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Do I need to raise my irrigation valve(s)? MrSmythe Landscaping & Lawn Care 3 09-03-2010 06:01 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
