Sprinkler Valve Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2015, 04:53 PM   #1
Rewards Points: 36
Sprinkler valve question
When a rotary sprinkler would not shut off at the timer the gardener told me what to do by telephone. I must have damaged the part identified by an arrow in the photo by not loosening the nut first. The plumber did shut it down for me. The gardener may have worked on it since but I don't know for sure. The sprinkler works but the other valves are apparently fully open while the one on the left is somewhat closed still. I cannot find any tool to turn it back to the fully open position. Does it matter or will opening it up to the fully open position (if possible) allow more water to flow? Thanks for any thoughts.
maintenance,man is offline   Reply With Quote
Tags
sprinkler system , valves
Well check valve problem, well question maxalex Plumbing 7 08-21-2016 02:21 AM
Sprinkler pressure release valve question syllinx Plumbing 0 12-04-2014 06:32 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
New sprinkler valve leak question Pawl Landscaping & Lawn Care 3 09-03-2012 08:41 PM
