I'm about to convert a section of a sprinkler zone (1 of 3 zones) from regular spray heads to micro sprays. The area to be converted is a slightly raised bed that is on the same zone as a section of the lawn and is fed from a lateral line (1/2") off of the main line (1"). There isn't any issues with exceeding the water supply.
After talking with a guy at the local irrigation shop, I was told that I could connect a spray head conversion body to the very end of the lateral in the raised bed and cap off the risers before it. The conversion spray body has a 20-30 psi regulator built in. On the top of the conversion spray body, there is a nipple that I connect 1/2" poly and I would just run that down the bed and connect my micro spray nozzles. The pressure in the system is 55 psi and all the spray bodies in the lawn are Rainbird PRM 30 (30psi regulated).
The reason I want to do this is the plants in the bed will get watered much better with much less wasted water (compared to spray bodies watering all the dirt in between the plants as well). Also, I only have three valves and to add more would be a major ordeal since a paver patio separates the valve manifold and the lawn area.
Does anyone have any opinions about how this will work and any pitfalls to look out for?
Thanks.
Thanks.
